jwade |
Member ![]() ![]() Group: Members Posts: 94 Joined: 23-February 03 From: Los Angeles, CA Member No.: 340 ![]() |
OK, so the two new axles are in and the car has been running fine for the last
month or so. BUT, just yesterday, as I was taking off from a light, the transmission slipped out of first into neutral as I accelerated from a stop. This happens only in first and the car shifts fine otherwise. I attempted to adjust the shift linkage from inside but that didn't seem to help. I can hold the shift lever into first and keep it in gear until it's time to shift but what am I looking at to fix the problem? thanks, john (owning a 914= (IMG:style_emoticons/default/headbang.gif) ) |
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
Sounds like the engine mounts have broken. Easy to replace even with the engine in the car.
Lo-Fi Version | Time is now: 26th June 2024 - 05:02 AM |
