How to re-attach in cabin rear view mirror |
lmcchesney |
Jul 31 2006, 07:12 AM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
My stock rear view mirror came off yesterday. It had previously been glued to the mounting base. There is a small silver plate which the mirror has a mounting screw to attach the mirror to the base. The small silver base came out of the mount. Is epoxy glue, which is what I believe was used, the only method of attachement?
What has been found to be a reliable attachement method? Thanks, Larry |
Joe Bob |
Jul 31 2006, 07:24 AM
it's a single use two part glue that's available at Kragen, Pep Boys, FLAPS..........
SGB |
Jul 31 2006, 07:30 AM
yep. The should have the stuff at any flaps
brownaar |
Jul 31 2006, 12:31 PM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
I went through two applications of the cement made for rear view mirrors and the mirror fell off both times. Used JB Weld after that, mirror has yet to come off, that's been like three years.
Also, check out the resources section, somebody makes a trick rear view that mounts using the sunvisors center mount. |
neo914-6 |
Jul 31 2006, 12:35 PM
anyone have black adhesive, I don't want the silver metal to show?
turboman808 |
Jul 31 2006, 12:45 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
I tried gasket adhesive and it worked better then silicon. If you can find black gasket sealer that would work well.
I ordered a 928 mirror should be here in a couple of days. Hope it works better then the 3 mirros I have tried already (IMG:style_emoticons/default/blink.gif) |
Midtowner |
Jul 31 2006, 03:49 PM
Ooooo! Group: Members Posts: 652 Joined: 21-December 04 From: Sunnyvale, CA Member No.: 3,316 Region Association: None |
I recommend a search using the words "mirror" on this site. There is a thread strongly against using epoxy due to different expansion rates between the glue and glass. Net result is usually a round-ish crack in the windshield. I successfully attached by masking then sanding the glass surface using 600 grit, thoroughly cleaning the mating surfaces, and using the mirror attachment glue kit from FLAPS. Helps to allow a few days to dry before attaching the mirror to the base. (IMG:style_emoticons/default/biggrin.gif)
mihai914 |
Jul 31 2006, 06:34 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
(IMG:style_emoticons/default/agree.gif) Using a hard glue can result in windshiel cracking. The original pad from Porsche is something similar to two way tape and is gray in color. I used some 3M permanent outdoor mounting tape, I bought it from staples.
lotus_65 |
Jul 31 2006, 06:51 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
Jul 31 2006, 06:54 PM
Custom Member Group: Members Posts: 24,679 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
What type of car are those mirrors from...
Is it a BMW, or an Audi... Please tell... Rich |
Lo-Fi Version | Time is now: 2nd January 2025 - 12:37 PM |
