stock93 |
Member ![]() ![]() Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States ![]() |
I took the oil pump out and what do you know. The cam gear was LOOSE!!!!! This would explain the noise I was having. If you remember it was a rattling raspy sound that was rpm related but would quiet down around 3K rpm. It would also explain why when I adjusted the valves and then went back after running it for a few minutes and letting it cool till the next day that my valve clearances were off. This would be especially true because I missed tdc a couple of times and turned the engine back the other way. I take it this would make the fi not run well. Right? It had almost no power. The ghia with the 1500sp was ragging on me bad. I already sold the fi but I'm still not planning on staying with a 1.7.
My cylinder that had 110psi had only a little more than half the top compression ring. It looks like the whoever rebuilt it previously broke the ring and just decided to go ahead and run it. There were a few parts of fins broken off of the cylinders. John Attached image(s) ![]() |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Bummer! Start collecting 2.0 components and build a 2056. I have cylinders that can be bored to 96 mm I'll give ya cheap. They've been riding in my trunk for almost a year. (IMG:style_emoticons/default/w00t.gif)
mr914 |
914 Hillbilly ![]() ![]() ![]() Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None ![]() |
Bummer about the motor.
Good to know, I'm not the only one driving around with motor parts in my trunk for over a year. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:14 AM |
