Elliot_Cannon |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None ![]() |
Hi,
I am considering an air compressor for the garage. What is the smallest one I can get and still run tools, spray gun etc.? Cheers, Elliot |
sj914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 ![]() |
at least a 25-30gal 5hp model would work for a lot of air tools and such, but you can never have too big of a tank.
jnp914 |
Member ![]() ![]() Group: Members Posts: 177 Joined: 19-August 03 From: Las Vegas, NV Member No.: 1,046 ![]() |
Walk through the Craftsman tool section and take a look at the air tools you think you might be using. All of them have a data plate that shows the air consumption. Your compressor/tank system has to be able to stay ahead of the biggest air hog tool you expect to use.
anthony |
2270 club ![]() ![]() ![]() ![]() Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 ![]() ![]() |
I went through this buying decision a while back. I got a 25 gallon tank that puts out about 5-6 cfm. It's plenty for most tools you'd use in your garage. The only tool that runs out of steam fairly quickly is the die grinder. Note that some paint guns ask for 12 cfm or so.
The way I figured it was that I wasn't prepared to spend the money, sacrifice the space, or deal with the installation (usually 220v) for an 80 gallon 10-15 cfm monster tank so this one does 95% of what I'd ever ask it to do and it's portable enough for doing projects around the house. |
-P- |
P-Factor ![]() ![]() Group: Members Posts: 207 Joined: 1-July 03 From: Dallas, TX Member No.: 873 ![]() |
I have a 22g/5.5HP craftsman. Works fine. Die grinder and ratchet eat it up quickly though.
jnp914 |
If you are really going to get serious about a shop size air compressor, you might want to look at a dedicated 20 amp circuit for it. I am having a house built, and one wall of the garage has dedicated circuits for the toys.
Charles Deutsch |
Unregistered ![]() |
Check out the air compressors at http://www.sears.com/sr/javasr/search.do?B...s&vertical=TOOL . Sears even has some up for auction on ebay!
Air_Cooled_Nut |
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None ![]() |
When I bought my house I promised myself I'd buy a good air comprerssor, one that wouldn't have me wanting more. I bought a 6.5hp Craftsman 60-gallon vertical tank, 240V, 14.7cfm @ 90psi, 130psi max. I re-circuit breakered (for lack of a better word) my circuit breaker box and made a dedicated circuit for my compressor. Not one single solitary regret! I love it!! Save yer pennies and get the best unit you can.
I've been using my die grinder with some kind of semi-soft abrasive wheel to take the rust and paint off my 914 -- and finding more and more rust (IMG:style_emoticons/default/mad.gif) and shoddy patch repair on the nose/headlight assemblies....mother #$@!ing previous owners (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/finger.gif) -- and the grinder definitely keeps the compressor cycling. Tools are spendy! I recommend a tire inflation kit and air blower kit --> http://www.sears.com/sr/javasr/product.do?...pid=00916391000 Then a die grinder cuz that can be used as a drill and cutting tool and as intended, a grinder (IMG:style_emoticons/default/wink.gif) Don't forget to get a clear face shield to protect your eyes and ear muffs. Draining the air from the tank in a garage is NOISY and you don't want to damage your ears (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 05:46 AM |
