> Can you use 911 engine mounts for the tranny?
PRS914-6
post Aug 20 2006, 05:52 PM
Excellence Magazine Project 914 3.6
Group: Retired Members
I have heard that you can do this by stretching the holes. The flanges on the mount look a little wimpy to do this. Anyone done it with a big motor?
The 911 sits on top of a hole getting supported all the way around. This would only be supported by the bolts and washers. Not sure I'm comfortable with it.
Replies(1 - 13)
Aaron Cox
post Aug 20 2006, 05:55 PM
Professional Tinkerer
911 sport mounts are used all the time...
you are better served by weltmeister or wevo pieces
turboman808
post Aug 20 2006, 05:58 PM
yes I even have a 911 sports mounts laying around the house. The wevo are better though.
IronHillRestorations
post Aug 20 2006, 06:08 PM
I. I. R. C.
The easiest way to make them fit is just squeeze the brackets in a little. You've only got to get a 1/4", and I just take a monster HD C clamp and pinch them together.
I've heard good things about the WEVO's, but no first hand experience.
post Aug 20 2006, 06:14 PM
Resident German
i'm currently running the 911 sport mounts. i did *not* have to tinker with the mounting holes, but your milage may vary ...
they are holding up very well so far, i just had the engine out the other day and there was no deformation or any kind of other obvious stress symptoms on the mounts ...
and yes, (IMG:style_emoticons/default/agree.gif) the WEVO mounts are certainly nicer still ...
(IMG:style_emoticons/default/smile.gif) Andy
GeorgeRud
post Aug 20 2006, 08:36 PM
Unless money is tight, get the WEVO mounts. They fit perfectly and the car never shifted as well.
rickyhgarcia
post Aug 20 2006, 09:03 PM
UPS truck is here...
Somewhere I read the 911 engine mounts were designed for an engine resting on them...and not for a transmission hanging off of them. Based on this bit of info I thought using the 911 engine mounts was not the right choice.
Therefore, I bought a set Wevo´s from the club store...which are specifically designed for a hanging 914 transmission.
Trekkor
post Aug 20 2006, 09:18 PM
I do things...
I use 911 sport's all around and did not need to modify or feel bad about it (IMG:style_emoticons/default/wink.gif)
KT
PRS914-6
post Aug 20 2006, 09:34 PM
Well, it sounds like everyone is having pretty good luck with the sport mounts. Thanks for the replies.
Unfortunately, I bought a roller with no original mounts to compare with. Can someone provide the thickness of the metal flange area of the OEM mount area that bolts to the car? I would like to compare it to the 911 mount thickness before I make a final decision.
Off the Wevo site:
NOTE; A 914 transmission mount version will be available in April 2005. The 914 hole spacing is close – but not the same as the 911 and the WEVO SS Engine Mount body should not be slotted.
post Aug 20 2006, 10:31 PM
Resident German
QUOTE(rickyhgarcia @ Aug 20 2006, 08:03 PM) *
i'm no 911 expert but doesn't the 911 engine mount bar *hang* off the mounts, just like a 914 transmission ...
(IMG:style_emoticons/default/confused24.gif) Andy
PRS914-6
post Aug 20 2006, 11:07 PM
QUOTE(SirAndy @ Aug 20 2006, 09:31 PM) *
Andy, Yep, same way.
The difference is like I said above, the mount sits in a hole so the mount is supported all the way around instead of hanging off 2 bolts and why I want to know the thickness of the metal....
post Aug 20 2006, 11:25 PM
Resident German
QUOTE(PRS914-6 @ Aug 20 2006, 10:07 PM) *
yes, i understood that part. (IMG:style_emoticons/default/biggrin.gif)
i'm nowhere near my car right now and i already dropped off my box of 911 sport mounts for the RJ mount with mark, so i can't take a measurement for you right now ...
i did check them mounts when we put the engine back in and they did not looked warped or deformed ...
a simple solution would be to add a "brace" to the mount very much similar to what you machined for your shifter (the thing with the lip for the boot) ...
just make a flat piece of metal with a flanged edge for stability and add it under the 911 mount to give it support.
should be easy for you to make ...
drive-ability
post Aug 20 2006, 11:43 PM
I am using them with my V8 and 930 transmission. I haven't had any issues even hammering the throttle. I will say with my V8 I tried to use them on the engine cross-brace and they pulled right out in minutes on the road.
rickyhgarcia
post Aug 21 2006, 08:52 AM
QUOTE(SirAndy @ Aug 20 2006, 08:31 PM) *
OOpps...I guess you should not believe everything you read.
- Lo-Fi Version Time is now: 2nd October 2026 - 04:02 AM
