Compression test values for a rebuilt TIV |
So.Cal.914 |
Aug 23 2006, 01:28 AM
You can flycut the 1.7 heads and use them with 96's, you can also use all the
other 1.7 parts (other than the crank, rods & P/C's) to build a 2.0 displacement engine. But I would change the cam. |
Lo-Fi Version | Time is now: 27th December 2024 - 03:03 AM |
