L-Jet with a header?, should be okay right??? |
Mueller |
Aug 22 2006, 10:53 AM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
if I get that L-jet from Britt, I'd like to throw it on my 1.8 so that I can re-do the wiring harness correctly for my LINK FI...
currently the 1.8 is bone stock except for the Mallory distributor and the ceramic coated european racing header....I'm thinking it'll be okay, just wondering if the better flow from the exhaust would cause any "hiccups" (IMG:style_emoticons/default/confused24.gif) |
Brando |
Aug 22 2006, 12:44 PM
No, it shouldn't. You get problems with L-Jet when you run cams that are made for carbs and have alot of overlap.
Aaron Cox |
Aug 22 2006, 12:46 PM
i dont think it will care mike.....
what LINK EFI are you running again? |
bd1308 |
no problems at all man
Roll it if ya get it Carb cam causes some issues, but headers only should be fine. I know a guy that runs straight pipes out of his bus...L-jet runs fine. b |
Lo-Fi Version | Time is now: 26th December 2024 - 12:43 PM |
