> Transmission Whine under load
bd1308
post Aug 23 2006, 06:38 AM
Sir Post-a-lot
I think I need a intermediate plate with some good but used bearings in them. These things are pressed in correct?
I'm just thinking aloud. Entertain me (IMG:style_emoticons/default/smile.gif)
b
jr91472
post Aug 23 2006, 06:48 AM
"I'm pacing myself sergeant..."
Yep, pressed in. Fairly easy to replace the bearings. The hard part is removing the gear stack from the plate and then paying for the bearings (or finding good used ones).
There is probably nothing wrong with your intermediate plate. In fact you really want to keep that plate matched with the current ring/pinion setup. Otherwise you run the risk of messing up the pinion depth and creating a whole new "whine".
Just replace the bearings. (IMG:style_emoticons/default/beer.gif)
Let me know if I can help.
JPB
post Aug 23 2006, 06:49 AM
The Crimson Rocket smiles in your general direction.
Ya ain't got no juice in the box brother or at least, that would be my first guess.
(IMG:style_emoticons/default/beer.gif) If ya wanna do her, ya gotta juice her!
bd1308
post Aug 23 2006, 07:02 AM
Sir Post-a-lot
juice is full to the brim friend.
Nasty stuff that juice is though.
bd1308
post Aug 23 2006, 07:03 AM
Sir Post-a-lot
QUOTE(jr91472 @ Aug 23 2006, 06:48 AM) *
Well ya gots any of dem bearings?
Bleyseng
post Aug 23 2006, 07:12 AM
Aircooled Baby!
Hard to find good used ones as the upper bearing is usually toast from all these years of low oil.
get a new one.
I take it the noise is in 2nd/3rd?
bd1308
post Aug 23 2006, 07:16 AM
Sir Post-a-lot
OK here goes...
1st gear no noise
2nd gear slight noise
3rd gear noise
4th slightly less than 3rd
5th almost no noise
pitch DOES NOT VARY with speed, varies only with RPM.
I thought for a while it was the fan making some harmonic sound. Its hardly audible over the engine.
I have heard the low-oil noise and that sounded like straight-cut gears. Scared the shit out of me, and topped the tranny off. It happened after a six hour drive to Dayton,OH.
jr91472
post Aug 23 2006, 09:56 AM
QUOTE(bd1308 @ Aug 23 2006, 05:03 AM) *
Sorry no. I am running on a questionable set as we speak
bd1308
post Aug 23 2006, 10:18 AM
Sir Post-a-lot
Well I guess i'm in the market for some bearings.
What happens when they finally go? Grinding I know (experience with ball bearing motors and hard drives) but is there any metal particulates in the gear oil (assumably so)
b
bob174
post Aug 23 2006, 10:35 AM
QUOTE(bd1308 @ Aug 23 2006, 08:18 AM) *
b
My bearings had completely failed and when I dumped the oil out of mine it had a golden sheen from all the brass particles entrained in it.
bd1308
post Aug 23 2006, 10:37 AM
Sir Post-a-lot
Hmm...it probably munched on it for a while...or exploded huh?
b
Aaron Cox
post Aug 23 2006, 10:38 AM
Professional Lawn Dart
QUOTE(bd1308 @ Aug 23 2006, 06:16 AM) *
but doesnt speed vary with RPM?
non sequiter (sp) argument
bd1308
post Aug 23 2006, 10:42 AM
Sir Post-a-lot
Well aaron...
RPM varies with speed only because of the transmission.
Speed and RPM are independent, but connected only via the gear you're in.
But you already knew that...
What i'm suggesting is that the pitch of the whine (a la speed of the bearings flying around) doesnt VARY with the gear/speed i'm in.
I coudl be doing 3500 in 3rd and 3500 in 4th and still get the same PITCH of the whine. WHich leads me to believe that the problem lies on the input shaft side of the transmission.
BTW, I have no idea what word that is supposed to be.
b
Aaron Cox
post Aug 23 2006, 10:46 AM
ahh.... it is gear independant....
google it.
bd1308
post Aug 23 2006, 10:48 AM
Sir Post-a-lot
Google what?
I KNEW it was gear independent.
b
bd1308
post Aug 23 2006, 10:49 AM
Sir Post-a-lot
What im wondering is which shaft is the top one?
Is the input shaft the top one, or the output shaft?
My gut feeling is that upper bearing is the input shaft, IE that bearing is going bad.
b
Aaron Cox
post Aug 23 2006, 10:51 AM
google: non sequiter.... (sp?) but anyway...
yes. top shaft is the driven shaft (input) and bottom shaft is the drive (output) shaft....
bearings are $$$
call carquip in CO to see if they have any good used ones
bd1308
post Aug 23 2006, 10:52 AM
Sir Post-a-lot
is the upper bearing still 300 something bucks?
I could do that.
b
Aaron Cox
post Aug 23 2006, 10:53 AM
upper intermediate plate bearing? or upper bearing in the trans case....
2 bearings per shaft.... rollers in case, balls in the int...
bd1308
post Aug 23 2006, 10:56 AM
Sir Post-a-lot
so twice what I would posted....
Lemme check PP and CarQuip.
If anyone has good ones lemme know.
I already know about the can of worms.
Dr Evil, If you have these items lemme know.
b
- Lo-Fi Version Time is now: 26th December 2024 - 11:09 AM
