Transmission Whine under load |
bd1308 |
Aug 23 2006, 10:58 AM
so I need these?
901 Intermediate Plate End Mainshaft Bearing, 914 1.7/1.8/2.0 (1970-76), 914-6 (1970-72), Each (Part 6) Brand: OEM [Photo] 999-053-025-00-M260 $192.25 901 Flywheel End Mainshaft Bearing, 914 1.7/1.8/2.0 (1970-76), 914-6 (1970-72), Each (Part 9) Brand: FAG [Photo] 999-110-008-00-M34 $232.25 |
Aug 23 2006, 11:10 AM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
There is probably nothing wrong with your intermediate plate. In fact you really want to keep that plate matched with the current ring/pinion setup. Otherwise you run the risk of messing up the pinion depth and creating a whole new "whine". actually, once the bearing starts spinning, it'll wear down the material around it. even if you get a new bearing, it won't fit tight no more ... seen it many times, take a look at the WEVO website for the *correct* fix ... (IMG:style_emoticons/default/smile.gif) Andy |
Aaron Cox |
Aug 23 2006, 11:11 AM
britt,
you need to open your box and find what you need to replace.... you may be dollars ahead buying another box.... |
John |
Aug 23 2006, 12:05 PM
QUOTE you need to open your box and find what you need to replace.... you may be dollars ahead buying another box.... I agree to some extent. Getting another "good" box may present a challenge as they are not as common in KY as they are in CA. Chances of getting another used box with all good bearings will be slim to none. I know for a fact that you will find more things wrong than just those two bearings once you open the box. You will only know what needs replacing when it is opened up. If you are not experienced in rebuilding and determining what needs to be replaced, you would be money ahead by sending your gearstacks out to Dr. Evil. I wish his services would have been available the first time I took a 901 box apart (some 20 years ago). I would have sent it to him. Alas, I learned how to rebuild them myself and they are pretty darn durable unless you over-stress the crap out of them (too much torque kills them). A second "temparary" box while you rebuild your "keeper" box is always a good idea if you need your car to drive. Good luck with your cheap bearing hunt. |
Bleyseng |
Aug 23 2006, 02:00 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Dr Evil |
Aug 23 2006, 02:44 PM
Send me your transmission! Group: Members Posts: 23,034 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I PMed you already. I have, new too if you so desire for less than what you stated. So far I agree with all fo the good advisxe given here as well.
Take the box apart and LOOK before you leap. You may not need a second donor. I can get you anything you need for less than the donor, and a donor will need a rebuild, too. Trust me. The bearing on the upper shaft is the one to die when the oil level is not maintained as it is not soaking in it like the pinion int bearing. If you fry a roller bearing (forward bearing ont he shaft) then you will be hating life as they are pricey.....and I have. PM me when you figure out what you need to do. |
bd1308 |
Aug 23 2006, 08:35 PM
I think i'll do this:
1)Find/Look for a good used tranny to roll with. 2)Aquire parts to rebuild mine. 3)Wait for used tranny to cough, and then throw in my good tranny. I need to fix a small leak in my tranny anyway, this will take care of the leak too. b |
Zenbruddah |
Aug 23 2006, 10:58 PM
Newbie Group: Members Posts: 8 Joined: 1-May 05 From: Phoenix, Az Member No.: 4,007 |
My transaxle whines as well but only at highway speeds at the top of 3rd, 4th and 5th.
bd1308 |
Aug 24 2006, 06:39 AM
Mine too, a soft whine.
Not the straight cut gearish whine sound, but just a gentle whine. I'll keep the tranny full and see what happens. There is a pullA Part near me that has 3 914s. b |
Aaron Cox |
Aug 24 2006, 10:37 AM
i cant hear my tranny over carbs, header, and ear plugs LOL....
i can hear second chirp tho (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 27th December 2024 - 02:33 AM |
