Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,191 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
it's been a while since i started this project. i had all the parts, but i was waiting for the right time to redo the complete rear suspension ...
yesterday, i went up to McMark's and we took out the old trailing arms and axles and shocks and prepared my new trailing arms and the axles. McMark finished the job today, and now i have: - new (unbend) trailing arms - new mueller roller bearings - new koni adjustable shocks - new axles with brand new 944 CVs (IMG:style_emoticons/default/smilie_pokal.gif) Andy PS: for the axles, i used, tranny to wheel: 915 (911, '75 - '79) coarse spline 6-bolt 100mm outputshafts -> 944 100mm CV -> modified 914 axle shaft -> 944 100mm CV -> 911 ('75 - '79) 6-bolt 100mm stub axle -> 911 ('69 - '73?) hub = real 5-lug! on top, the stock 914 axle, bottom, the new axle using 944 and 911 parts: ![]() and installed: ![]() |
the main benefits of doing this, IMHO:
- 944 CVs are still readily available brand new for reasonable prices. - 944 CVs are slightly bigger and wider than stock 914 CVs. - real 5-lug hubs instead of redrilled 914 hubs. (IMG:style_emoticons/default/smile.gif) Andy |
pek771 |
Member ![]() ![]() Group: Members Posts: 275 Joined: 23-November 05 From: Conover, NC Member No.: 5,175 Region Association: None ![]() ![]() |
Nice work, Andy!
What did the mods to the axle shaft consist of? Pat |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
not andy,
but you have to turn off a "bump/lip" on each end of the shaft where the stock dust boot sat iirc |
Chris Pincetich |
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California ![]() |
(IMG:style_emoticons/default/drooley.gif)
I think you will see the yellow through your wheels. sweet. Looks pretty fast on those jackstands! (IMG:style_emoticons/default/beerchug.gif) |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
not andy, but you have to turn off a "bump/lip" on each end of the shaft where the stock dust boot sat iirc Nope. The 944 CVs are wider, so they need more room on the axle splines. (IMG:http://www.914world.com/bbs2/uploads/post-11-1123464006.jpg) |
Aaron Cox |
not andy, but you have to turn off a "bump/lip" on each end of the shaft where the stock dust boot sat iirc Nope. The 944 CVs are wider, so they need more room on the axle splines. (IMG:http://www.914world.com/bbs2/uploads/post-11-1123464006.jpg) ahh yeah. i lied. LOL. that makes it mo betta |
fiid |
Turbo Megasquirted Subaru Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California ![]() |
OMG. That's delicious.
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
That is exactly what I did to 914-6 axle shafts to make 911 CV joints fit on them
Attached image(s) ![]() |
Eddie914 |
Unregistered ![]() |
What model and year did the stub axle and outputshafts come from?
Where is the 100mm measured on the stub axle? I have one large four bolt stub axle and one six bolt. Not sure or the origin. The outputshafts I have are from an '86 915 and are also four bolt. Thanks Eddie |
What model and year did the stub axle and outputshafts come from? 915 output flanges and 911 stub axle came from a mid to late '70s 911 (~'75 - '79) and the hubs came from a early 911 (~'69 - '73?) ... 100mm is the dia. of the CV, so the flages and stubbies fit a 100mm CV ... (IMG:style_emoticons/default/smile.gif) Andy PS: and yes, stubbies and flanges and CV's are all 6-bolt ... |
jonwatts |
no rules, just wrong ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 ![]() ![]() |
Andy, your avatar looks weird. Did you have some work done?
Oh, and cool suspension stuffs. |
Andy, your avatar looks weird. Did you have some work done? yeah, i spent about an hour in front of two mirrors with a clipper and razor blades trying to get the hawk straight and centered ... (IMG:style_emoticons/default/biggrin.gif) not perfect but gud enough for me ... (IMG:style_emoticons/default/aktion035.gif) Andy |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
it's been a while since i started this project. i had all the parts, but i was waiting for the right time to redo the complete rear suspension ... yesterday, i went up to McMark's and we took out the old trailing arms and axles and shocks and prepared my new trailing arms and the axles. McMark finished the job today, and now i have: - new (unbend) trailing arms - new mueller roller bearings - new koni adjustable shocks - new axles with brand new 944 CVs (IMG:style_emoticons/default/smilie_pokal.gif) Andy PS: for the axles, i used, tranny to wheel: 915(911) coarse spline 6-bolt 100mm outputshafts -> 944 100mm CV -> modified 914 axle shaft -> you're welcome (IMG:style_emoticons/default/smile.gif) 944 100mm CV -> 911 6-bolt 100mm stub axle -> 911 hub (real 5-lug!) on top, the stock 914 axle, bottom, the new axle using 944 and 911 parts: and installed: If you decide to sell those other parts, I think those spacers I made for you will need to be trimmed down a bit hieght wise.... |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
Kind of look like Sting when he was young, like in Quadraphenia, but without the
mohawk. I like the upgrades, looks bada$$. |
McMark |
Actually, Mike they were about 0.25mm too short. Completely usable (IMHO), but visibly short. Not your fault, mostly Andy's. We need to buy that guy a digital caliper. (IMG:style_emoticons/default/smile.gif)
barrym |
Member ![]() ![]() Group: Members Posts: 88 Joined: 12-October 14 From: Australia Member No.: 18,008 Region Association: None ![]() |
dragging up the old posts here ... which 944 cv joint did you use ? 944 s2 turbo ? are they all the same ?
thanks |
dragging up the old posts here ... which 944 cv joint did you use ? 944 s2 turbo ? are they all the same ? No turbo, just yer plain old 944 ... (IMG:style_emoticons/default/smile.gif) |
Cracker |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States ![]() ![]() |
Very nice Andy. Have you had a failure in the past or was this a proactive move on your part?
Tony |
Very nice Andy. Have you had a failure in the past or was this a proactive move on your part? I wanted real 5-lug in the rear, not re-drilled hubs. The slightly larger CVs were an added bonus. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 20th April 2025 - 08:26 AM |
