914 color codes page ... |
Sep 14 2006, 04:38 PM
Resident German Group: Admin Posts: 41,712 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i added a page with all the available 914 color codes.
i'm sure i missed a few and some might not be correct, so please, have a look at the list and give me some feedback ... http://www.914world.com/bbs2/index.php?act=colors (IMG:style_emoticons/default/type.gif) Andy PS: that list is dynamic and will eventually be used to check against color codes supplied in the VIN section, so i'd like to get this as accurate as possible ... |
1970 Neun vierzehn |
Sep 14 2006, 04:46 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
L11E is Canary yellow. Nice chart (IMG:style_emoticons/default/clap56.gif) Great work!
G e o r g e |
Sep 14 2006, 04:48 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
flesburg |
Sep 14 2006, 05:01 PM
Senior Member Group: Members Posts: 506 Joined: 22-November 04 From: Pontiac, IL Member No.: 3,162 |
Sunflower yellow was available in 74. Could make a copy of the paperwork that came with my car in 74 if you need proof.
JPB |
Sep 14 2006, 05:04 PM
Cool chart and I can see mine was Willow Green at on time. Then it was silver and then red which is what it is getting right now.
(IMG:style_emoticons/default/beer.gif) Nice to know stuff here! |
tomamafone |
Sep 14 2006, 05:13 PM
There's no "I" in Teener Group: Members Posts: 109 Joined: 7-January 05 From: Hollywood, CA Member No.: 3,414 |
you might want to put a black border around the "ivory white" section. or a dot or something to tell us when they were offered. great job though!
Jeroen |
Sep 14 2006, 05:15 PM
nice job!
Sep 14 2006, 05:16 PM
Sunflower yellow was available in 74. Could make a copy of the paperwork that came with my car in 74 if you need proof. fixed, that was a typo on my end ... (IMG:style_emoticons/default/rolleyes.gif) Andy |
Sep 14 2006, 05:18 PM
you might want to put a black border around the "ivory white" section. or a dot or something to tell us when they were offered. great job though! what, you can't see the difference between white and light ivory? (IMG:style_emoticons/default/biggrin.gif) ok, will do ... (IMG:style_emoticons/default/type.gif) Andy |
Sep 14 2006, 05:20 PM
also, anybody know for sure what the date-split for early and late 914-6 color codes was?
right now, i have them both listed as possibilities from '69 to '72 as i don't know when the split occured ... (IMG:style_emoticons/default/confused24.gif) Andy |
davep |
Sep 14 2006, 05:21 PM
914 Historian Group: Benefactors Posts: 5,163 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I'm emailing my list.
The xx10 code only ever showed the xx, never the 10. This code basically says the roof was black (10) for examples see 911 targas. The xx10 code was aparently used from the earliest 914/6 until about 1972 when the VW code was used. To my knowledge, the Porsche code was never used, I have seen no examples of it. My list also shows another code that shows up on the COA. |
Sep 14 2006, 05:36 PM
I'm emailing my list. i got it. thanks! (IMG:style_emoticons/default/beerchug.gif) question: are you sure black has the code "L041" with a numeric 1 at the end? all other codes end with a letter and i was under the assumption the code was "L04I" with an uppercase i at the end ... anyone know for sure? (IMG:style_emoticons/default/idea.gif) Andy |
davep |
Sep 14 2006, 05:41 PM
Absolutely positive on the L041. Yes it is rather unique in that way. I'd put the different codes on one line since they are fully equivalent. It does shorten the list to a more compact size.
davep |
Sep 14 2006, 05:49 PM
Just checked my book. The VW code superceded the xx10 code beginning VIN 9141430399. This was due to paint shop confusion.
Pat Garvey |
Sep 14 2006, 05:53 PM
Nice job Andy!
Is that hair Bahia Red? Pat |
Sep 14 2006, 05:55 PM
The xx10 code only ever showed the xx, never the 10. This code basically says the roof was black (10) for examples see 911 targas. The xx10 code was aparently used from the earliest 914/6 until about 1972 when the VW code was used. To my knowledge, the Porsche code was never used, I have seen no examples of it. My list also shows another code that shows up on the COA. ok, so i fixed the xx10 codes ... just to clarify, are you saying that the "early" 3-digit 914-6 codes were actually never used ??? (IMG:style_emoticons/default/confused24.gif) Andy |
Sep 14 2006, 05:58 PM
Absolutely positive on the L041. Yes it is rather unique in that way. I'd put the different codes on one line since they are fully equivalent. It does shorten the list to a more compact size. fixed L041 ... i'll look into merging the similar lines ... (IMG:style_emoticons/default/smile.gif) Andy |
davep |
Sep 14 2006, 06:00 PM
Correct. Going back to 0012 they have two digit code, confirm Glenn?
0033 actually has 29/29, no idea why. No indication the 3 digit code was ever used. We could add the German color names. So many codes have multiple names. |
McMark |
Sep 14 2006, 06:07 PM
Ack, I've been superseded. (IMG:style_emoticons/default/tongue.gif)
davep |
Sep 14 2006, 06:21 PM
I've worked on the paint codes for 25 years, just never posted it before. Andy still has to split the silvers. The changeovers were not clean cut either. L96D extended into 1975, and some were used after L99A came out.
It is much the same story as the chassis numbers. The 9000 series came out but were interspersed with 9500 series for a while. My LE falls on the late side of the rear brake pressure reducer change, but has the early style anyway. It's engine should have been used in October not March. |
Lo-Fi Version | Time is now: 30th June 2024 - 09:35 PM |
