Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Yes on the design. I like that a lot.
KT |
Lou W |
"Here Kitty Kitty" my ass...... ![]() ![]() ![]() ![]() Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain ![]() |
JPB |
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 ![]() |
would one want to keep the surface wet while working out the bubbles? I used to work in a shop where we screened big decals, and the material used was pretty porous- water soaked through easily. We put a little dish soap in the water too. I remember the whole sheets would slide around pretty easily. I was always surprised that the "trapped" liquid dried out, but it did. (IMG:style_emoticons/default/agree.gif) You can install 100ft. of decal with that method. (IMG:style_emoticons/default/beer.gif) Hello to my sign shop brother. Niagara Falls on the canadian side was all mine bro in lit signs, awnings, banners and neon. |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
stay away from the alcohol...water and a mild soap...NO ALCOHOL!!
...well maybe 12oz in a frosty mug... (IMG:style_emoticons/default/smile.gif) |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Joe, my cutter is 30 inches wide. However the targa top is about 31.5" wide. (IMG:style_emoticons/default/dry.gif) If you can live with a bit of a gap at the front or back, or a two piece sticker, I can help out.
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
I use exaxto blades to pop bubbles...also on a top, you can either section like Mark said or use a black border to compensate for the width issue.....not like a Porsche owner has ever had to compensate......
McMark |
Electrical tape makes a good border. Gotta work the Home Depot into each project. (IMG:style_emoticons/default/wink.gif) Where's Trekkor when you need him. (IMG:style_emoticons/default/lol2.gif)
jasons |
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None ![]() |
stay away from the alcohol...water and a mild soap...NO ALCOHOL!! ...well maybe 12oz in a frosty mug... (IMG:style_emoticons/default/smile.gif) Whats wrong with the alcohol trick? It was recommended in a couple of different sets of directions of products I used. |
seanery |
it has a negative reaction with the adhesive. So does Amonia. Some folks recomend windex, but you must make sure it has no Amonia in it. It's worse than the alcohol.
HeloMech |
Go Ahead, Get Pistoph! ![]() ![]() ![]() Group: Members Posts: 691 Joined: 31-August 05 From: Roy, WA Member No.: 4,718 Region Association: Southern California ![]() |
xacto blades are worse than pins. They leave a straight line cut and are more likely to tear than the round holes. Even in the sign shops they carry pin tools and burnishing tools combined in one little stick. The round hole is less likely to start a run.
jasons |
Joe Bob |
xacto blades are worse than pins. They leave a straight line cut and are more likely to tear than the round holes. Even in the sign shops they carry pin tools and burnishing tools combined in one little stick. The round hole is less likely to start a run. Sorry....but that's bullshit. I use exactos ALL the time.....I have stuff that's been on for years and they look fine....just don't be heavy handed. |
Boojum |
Member ![]() ![]() Group: Members Posts: 95 Joined: 31-July 06 From: Denver, CO Member No.: 6,550 ![]() |
Depends on the decal, and what material you're using... I used to work at a
My preferred method for large to small decals like yours, while doing it by myself or with some extra hands: Whatever you do, get one of these if you aren't using one: (IMG:http://estore.websitepros.com/stores/1262528/catalog/IMG_0041.jpg) Our shop usually included one of these, I don't know if your decal guy gives you a proper squeegee or not, but this is critical. Gold squeegees are harder than blue ones, which means that the blue ones will allow you to follow contours much more easily, but they wear out a bit faster--which shouldn't be a concern unless you're planning to do a fleet, and they cost around a buck anyway. The anti-friction sleeve is also helpful, but not strictly necessary. It allows you to press harder and not cause friction related problems. Also, go get some of the GREEN or BLUE 3M masking tape, from a home supply store or paint supply, etc. Green has stronger adhesive which will allow you to be more violent, and neither will harm your paint. First, I would tape the decal firmly into position, in the exact position it needs to be in. Anchor it firmly on both of the sides of the car, but leave the other edges alone--the direction facing the engine lid and windshield respectively. Cut a piece of masking tape a few inches wider than your decal in both directions, six inches or so total. Take that piece of tape and place it so that it goes north/south--in other words, across center of the shorter axis. Cut some more pieces and put them right along side of this one so that your line of tape covers more surface area. edit: just found a picture gallery that explains exactly what I was getting on about with much fewer words: Clicky Here look here, and the rest below will make much greater sense. We're going to use this longitudinal anchor as a hinge, if you hadn't already guessed... Decide which side of the decal you want to apply first, and anchor the opposite side of the tape MUCH better, so the decal won't have a tenancy to twist. Put a piece of tape every few inches, you can't make sure it's down good enough. An extra pair of hands at this stage will be helpful, especially if you're doing this on a vertical surface. Now take the tape off the side that you want to apply first, and pull it over the other side--the one that you just taped the heck out of in the last step, but be extremely careful not to pull so hard that you kink your decal on your tape hinge. You don't want it to go 180 degrees, and put a fold in your vinyl, in other words. Peel the backing liner off this side of the decal, so that it lays in the direction it previously did. For the sake of clarity, the decal that's stuck on the pre-space tape is now laying upside down, on top of the other side of the decal. The adhesive side is pointing up, and the backing paper is off, and your decal is not kinked.. Lift the backing paper up off your targa, and using a brand new, or like new straight razor blade or very sharp pair of scissors, cut the backing material away from your pre-space tape and vinyl, so that your cut is parallel with your tape hinge. The idea is that you want a very clean cut. You don't want paper bits going everywhere, because they'll get stuck to your decal and make it look bumpy. Since you're doing a roof on a car, you're probably not going to have the arm length to do this alone, unless you want to stand on your engine lid. You're going to need a helper. You want to pass the lose side of the decal over to your helper, being careful not to let any part of the decal touch your application surface. It's best to keep the lose side quite tense, but not tense enough that you're going to rip your tape hinge off, and you'll want it held up by your helper an inch or so on the lose side. Take your squeegee and hold it perpendicular to your tape hinge. Using an arcing motion, starting from near the center of the decal, press your squeegee firmly down, and arc away from your hinge and to the outside of the decal. The most critical part of this is making sure that you get the vinyl along the cut of your backing paper down really good, and bubble free, otherwise there will be a line of bubbles. Being sure to overlap your strokes by a healthy amount, slowly apply everything towards the direction of your helper... And tell your helper that they need to lower the material as you go that direction, but they must absolutely keep it tensioned, and off the application surface, or the whole deal is likely to become FUBAR. The one thing that is going to give you bubbles is not taking your time and not generously overlapping your strokes. Now you'll take all of your anchoring tape off the other side, including your tape hinge, because the pre-space tape will become the hinge, and you just do that side like you do the other side. ------------------------------------------------------------------------------------- There are a lot of steps, so sorry if this is too long or isn't especially clear, or even comprehensible (it's bed time, but I wanted to get this reply in) I would have loved to give you step by step photos, but I'm not doing that sort of thing any more, and I don't have the instruction sheet we shipped out with our decals. I've found that this is the single most efficient way to apply decals as big as 10'x50", and anything in between. Also, I don't buy into the water and soap thing, because it's just not effective for this situation, it's very messy, and I have doubts about the soap being friendly to the longevity of decals that will be exposed to varying temperatures: My experience is that the decal will laminate, and cause wormy looking bubbles, because of the natural expansion and contraction cycle of vinyl, and it seems like the soap film makes the adhesive less sticky, and will cause a film in between the adhesive and the application surface. Just to give you an idea of some of the stuff I saw whilst doing this kind of thing, some of our vinyls would stretch as much as 1/4" over 4' if there was a 50 degree temperature difference between one decal and another identical other, and the backing material allows it to flow out a certain amount, whereas the interference between the adhesive and a real application surface doesn't allow that to happen, causing tension in the vinyl when it gets cold, and when it gets hot it goes wormy because the vinyl stretched to a very small degree. If your decal wouldn't be sitting out in the blistering New Mexico sun for more than a few minutes, I'd say that you might be able to get away with the water/soap technique. Also, I too find a good exacto blade to work much better than a pin for bubbles, and they're sometimes inevitable. It dosen't matter if you've done it for five days for five years, even the best will encounter problems. Best of luck. |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
wow, what explicit instructions...
I agree with all statements, actually. The adhesion is certainly impacted by the soapy water application method, but it was the lesser of evils for my application capabilities. (IMG:style_emoticons/default/smile.gif) |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
you can hit the bubbles with an exacto blade and push out the air
wet application can make installing large surfaces easier (2 drops of babyshampoo or dishsoap in a spraybottle of water) degrease the surface before applying we did this one dry though (IMG:style_emoticons/default/wink.gif) (IMG:http://www.914world.com/bbs2/uploads/blog-3-1157913784.jpg) (IMG:http://www.914world.com/bbs2/uploads/blog-3-1157913850.jpg) |
Lo-Fi Version | Time is now: 20th June 2024 - 05:42 AM |
