dadsscooter |
Newbie ![]() Group: Members Posts: 7 Joined: 28-September 06 From: Michigan Member No.: 6,938 ![]() |
I haven't any oil pressure on reuilt 2.0. Had run for 15 seconds and when gauge didnt register shut it down to investigate. No oil pressure was confirmed by cranking engine with oil relief valve out... NO OILl! Also pulled valve cover and it was DRY! Had installed HD oil pump and gears turned fine when installed. I did however adjust the end play after installing the pump.
I had never pulled the oil pressure control valve from the case when rebuilding. Could this be it? Could the oil pump drive possibly become disengaged from the cam??? I realize any corrective action will most likely require removing my newly installed engine but am looking for any possible suggestions to follow. Fairly new to the air cooled scene. Please respond if you can help. Thanks, Mike |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Loosen the oil filter until there's a gap. Crank the engine (with the spark plugs out and the point wire disconnected) until oil comes out of that gap. Tighten the filter, clean up the mess, crank it 'til the light goes out. Bingo! Oil pressure.
BTW, it's BAD practice to start the engine without having cranked it for oil pressure. You just put a BUNCH of wear on the bearings. The established procedure is to crank it with the plugs out until the oil light goes out, then maybe a few more seconds. After that, you can install the plugs and run it at 1500 RPM or more at a steady speed for 20 minutes, shut it down, let it cool, and adjust the valves. The Cap'n |
dadsscooter |
Loosen the oil filter until there's a gap. Crank the engine (with the spark plugs out and the point wire disconnected) until oil comes out of that gap. Tighten the filter, clean up the mess, crank it 'til the light goes out. Bingo! Oil pressure. BTW, it's BAD practice to start the engine without having cranked it for oil pressure. You just put a BUNCH of wear on the bearings. The established procedure is to crank it with the plugs out until the oil light goes out, then maybe a few more seconds. After that, you can install the plugs and run it at 1500 RPM or more at a steady speed for 20 minutes, shut it down, let it cool, and adjust the valves. The Cap'n Thanks for your reply ... I had primed the filter and cranked it for a few brief trys with the coil wire off. Pump was also packed with light grease to help prime. Have pertronix... no points. I didn't think just cranking the engine would register on the gauge or make the light go out. We all learn from our mistakes. Does anyone know approximately how long it takes to get oil pressure by loosening the oil filter? If a oil pressure control valve is stuck, could it cause no oil pressure. I do know that there is a small drilling in it. Does anyone know if the stock oil pump is prefered over the Heavy duty one or if the HD has any known problems? Everyone has a opionion and I am ready to listen to any of them. I wish I had found the club earlier. Hopfully I will soon be able to share my 914 experiences with others. As for now my knowledge of small sports cars lies mostly with "Z" cars and Triumphs. |
Heeltoe914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 ![]() |
Start with what the Cap'n said and let us know. I have used many HD pumps and thay work great IMHO. It can take time to get pressure up. Is it a Mallory pump? And are you sure the sending unit and gauge are working.
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
I fill the filters up with oil too, but i know its not applicable to new/rebuilt engines.
Al Meredith |
Senior Member ![]() ![]() ![]() Group: Members Posts: 972 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 ![]() |
This happened to me on my last rebuild. Cranked and cranked and could not build pressure. I use a direct reading guage in the oil pressure switch hole. Same story as yours; new pump, greased, prefilled filter. I finally removed the filter and turned over till oil streamed streight down.... reinstalled the filter and everything worked fine ,. Listen to the capt'n. Al
Lo-Fi Version | Time is now: 3rd April 2025 - 07:03 PM |
