dmenche914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 ![]() |
My advice is no coolant lines inside the cabin. two reasons:
1. they really do get hot, you'll not like it in the summmr 2. if not all metal, welded up, they might spring a leak on you, and I mean ON YOU. (I have had that bad experience. ) it will scald you big time. in event of a crach, even all metal welded line may rupture, you do not want 240F collant on you in a crash. my adice is run metal lines under the car, or in beind the outer rocker. witht eh right line, placed carefully under the car, you loose very little if any clearance tot eh ground. I got a car with rectangular steel tubing for the line, they are only about 5/8 inch tall fit snug ont eh bottom of car, int eh depression on either sdie of the tunnel. No coolant lines in the cockpit, please!!! you will be much happier with them outside the cabin, really. |
TonyAKAVW |
That's my ride. ![]() ![]() ![]() ![]() Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None ![]() |
Actually the plan was (copying Bondo's idea) to run insulated aluminum tubes above the center tunnel and then once in the engine bay use hose, as well as up front.
Since I have a cable shifter in my car I will very soon have a much much taller center console/tunnel. That means the insulated tubes would be covered by a console. Therefore even in an accident it would be unlikely that I would get hot coolant on me. I want to be able to lower my car, put a flat bottom on it, and apair of venturi tunnels as well. Having coolant lines running under the car would interfere with that setup. -Tony |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
Has anyone ever evaluated the area behind the rear wheels- either with a scoop or other inlet, or perhaps dual radiators on each side? I'm not sure which way the opening should face, or what the orientation should be, but there is actual open space in there in the qp. It would be close to the engine, too.
jsteele22 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 ![]() |
Has anyone ever evaluated the area behind the rear wheels- either with a scoop or other inlet, or perhaps dual radiators on each side? I'm not sure which way the opening should face, or what the orientation should be, but there is actual open space in there in the qp. It would be close to the engine, too. Well, for a good vacuum, the openings should be on the front side of the wheel well. I'm not sure, but I think that the steel in that area is important structurally. Check twice before you cut ! |
jsteele22 |
my adice is run metal lines under the car, or in beind the outer rocker. witht eh right line, placed carefully under the car, you loose very little if any clearance tot eh ground. I got a car with rectangular steel tubing for the line, they are only about 5/8 inch tall fit snug ont eh bottom of car, int eh depression on either sdie of the tunnel. Any pics available of coolant lines behind the outer rocker panels ? Is there room for both lines to fit on one side ? |
wbergtho |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 ![]() |
I exit hot radiator air through the front hood and use a custom 3 core aluminum Fuidyne radiator and twin thermostatically controlled fans. It runs between 175-185 degrees. At speed, it runs at 175...at a dead stop for 30 minutes in 95 degree summer heat...it creeps up to 185. This design produces downforce...unlike the more popular technique of venting out the wheel wells or front trunk floor.
Attached image(s) ![]() ![]() |
wbergtho |
pic
Attached image(s) ![]() |
project-914 |
Member ![]() ![]() Group: Members Posts: 181 Joined: 2-August 06 From: Oklahoma Member No.: 6,571 ![]() |
This design produces downforce...unlike the more popular technique of venting out the wheel wells or front trunk floor. finally someone said it...THANKYOU...this is what I would do...but if you don't want to put a huge hole in your hood and you'd rather have a sleeper then it's not a good idea...I'm all about performance |
Lo-Fi Version | Time is now: 25th June 2024 - 10:17 PM |
