rear fender air intake scoops, who's done it, any pics.?? |
Elliot Cannon |
Nov 14 2014, 10:38 AM
The only problem with scoops in the rocker panel is picking up a lot more dust and water from the road surface. For what it's worth, that has never been a problem with mine. Attached image(s) |
nsyr |
Nov 14 2014, 04:02 PM
Because I Can Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 |
Does that help with getting air into the engine. I have always felt that the engine compartment is a low pressure zone, starving the engine for air at higher speeds.
VegasRacer |
Nov 14 2014, 05:57 PM
ELVIRA Group: Benefactors Posts: 8,709 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Sister.
Attached thumbnail(s) |
damesandhotrods |
Nov 14 2014, 06:43 PM
Senior Member Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
Does that help with getting air into the engine. I have always felt that the engine compartment is a low pressure zone, starving the engine for air at higher speeds. Porsche didn’t seem worry about it with 914-4 even when they raced when it when it was new. They didn’t open up the engine lid until they raced the 914-6… |
57lincolnman |
Nov 14 2014, 09:24 PM
Member Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
I am thinking about doing this. They would be small so it doesn't look like a rice racer, I like the idea of getting fresh air into the engine bay. who's done this?? got any pics?? I put a small scoop recessed into the rocker panel on the passenger side. It's low and very discrete. I took the stock rockers ones off and put on the ABS ones that say PORSCHE on them. It was easy to cut out the section I needed for the scoop. Just to make sure I had clearance in that recess between rocker and face of frame. I have A/C so I had to reroute the hoses to get the clearance. I suppose you could use it with the stock metal rocker but it would be harder. I put a hose connection on the back of the scoop that is routed underneath and goes to an auxiliary oil cooler with a shroud to make sure all of the ducted air blows across the oil cooler. It works great in the summer. I live in Atlanta and in 90+ summer temps the oil stays at 210-215 tops. In cooler weather like now I close it off with a rubber drain stopper (not very elegant but it works) because the oil wouldn't get to 180 otherwise. I can send pics if you like. |
Elliot Cannon |
Nov 14 2014, 11:18 PM
Chris914n6 |
Nov 15 2014, 12:02 AM
Jackstands are my life. Group: Members Posts: 3,428 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Here's something I was playing with. Enters thru the little grilles.
(IMG:http://www.914world.com/bbs2/uploads_offsite/lh4.googleusercontent.com-431-1416031342.1.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-431-1416031343.2.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh4.googleusercontent.com-431-1416031343.3.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh6.googleusercontent.com-431-1416031344.4.JPG) |
tomeric914 |
Nov 15 2014, 08:06 AM
One Lap of America in a 914! Group: Members Posts: 1,263 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
effutuo101 |
Nov 15 2014, 09:59 AM
Advanced Member Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
Here is a pic of mine. I have to finish the inside boxes for the air intake.
Mike Bellis |
Nov 15 2014, 10:57 AM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Nov 15 2014, 11:38 AM
914 Idiot Group: Members Posts: 15,067 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Here's something I was playing with. Enters thru the little grilles. Reminds me of Charlie Davis' setup: (IMG:http://www.914world.com/bbs2/uploads_offsite/members.rennlist.com-121-1416073111.1.jpg) Read about it here: http://members.rennlist.com/chuxter/TempTests.htm --DD |
boxsterfan |
Nov 15 2014, 09:35 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
For anyone who has used the Naca duct on the rocker, how did you route back behind it?
I was often thinking that when I restore my car I wanted to get rid of the jack posts completely on both sides. Put Naca ducts in the rocker panels where those would be. Cut a large enough hole in the long (where the jack post plate used to be) and connect to the tubes (normally used for heat). Either route those up to the engine bay for fresh air intake or point them at the trans or external oil cooler. Then just put in electric heat. Simple. (IMG:style_emoticons/default/lol-2.gif) Just kidding about electric heat. Maybe heated seats though. |
57lincolnman |
Nov 15 2014, 09:45 PM
Here is my solution. NACA duct cut into rocker panel with hose connection routed to auxiliary oil cooler. No problems with dust or water. Subtle and powerful. The NACA duct is very efficient to suck in air.[ Keeps oil at 210 degrees even on hottest days. In the colder months I close up the duct. attachmentid=475909]
57lincolnman |
Nov 15 2014, 09:51 PM
For anyone who has used the Naca duct on the rocker, how did you route back behind it? I was often thinking that when I restore my car I wanted to get rid of the jack posts completely on both sides. Put Naca ducts in the rocker panels where those would be. Cut a large enough hole in the long (where the jack post plate used to be) and connect to the tubes (normally used for heat). Either route those up to the engine bay for fresh air intake or point them at the trans or external oil cooler. Then just put in electric heat. Simple. (IMG:style_emoticons/default/lol-2.gif) Just kidding about electric heat. Maybe heated seats though. I posted pic that shows the hose routed to an auxiliary oil cooler that is shrouded to maximize air flow across the oil cooler. To get the space needed, I used Tangerine Racing street exhaust system which gives more room on the passenger side for the oil cooler to be mounted in a near vertical position. |
Jetsetsurfshop |
Nov 16 2014, 11:24 AM
Senior Member Group: Members Posts: 815 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
I did this for my rear cooler too. Check post #43 for route pictures. That's three inch duct work. I moved my oil cooler to the front of my car. May keep this for a trans cooler, not sure yet.
http://www.914world.com/bbs2/index.php?sho...27027&st=40 |
carr914 |
Nov 16 2014, 12:47 PM
Racer from Birth Group: Members Posts: 122,832 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
veekry9 |
Nov 17 2014, 04:52 AM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
Sure,with side mount rads,intercoolers,you would need inlets/scoops/ducts. http://www.fiero.nl/forum/Forum3/HTML/000116-28.html |
aircooledtechguy |
Nov 17 2014, 11:03 AM
Apples and oranges here since my car is not a Porsche body, but these are the NACA ducts on my car.
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1416243825.1.jpg) I'm no mechanical engineer nor did I ever take a physics class. . . With that said, the NACA ducts on the Squarsche work better than I had anticipated. (IMG:style_emoticons/default/piratenanner.gif) Before the latest revamp of the car with stock cooling, I would see a spike in head temps above 60mph (400F and climbing). Once I added the NACA ducts, head temps usually sit at or below 350F (have never gone over 375F) and above 70mph, the engine runs cooler 290-325F (even with the higher engine speeds and higher load). NACA ducts not only work well, but in my experience they become more efficient with speed and just work better and better by design. |
mr2by4 |
Nov 17 2014, 03:32 PM
Member Group: Members Posts: 182 Joined: 9-December 07 From: Fort Worth Member No.: 8,439 Region Association: Southwest Region |
GeorgeRud |
Nov 17 2014, 05:29 PM
Why not go all out?
Lo-Fi Version | Time is now: 7th January 2025 - 08:41 PM |
