Gotta go, gotta go, gotta go..., Gotta take a leak (out) |
Carlitos Way |
Oct 17 2006, 05:04 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
Well... my engine is REALLY leaking oil right now. I'm talking about a quart of oil per 3/4 tank. Howard thinks it might be blow by. Can anyone tell me how to do a leakdown test and or any other test I might run to figure out where the oil is coming from?
bd1308 |
Oct 17 2006, 05:06 PM
are you having some HUGE smoking issues?
My bet is the oil pressure switch, when mine broke it leaked 2 quarts every 1/8 tank. |
Crazyhippy |
Oct 17 2006, 05:37 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
IS it leaving a puddle?
Where on the motor is it coming from? Does the dipstick end up smelling like gas? I can look at it late this week if needed. BJH |
Howard |
Oct 17 2006, 06:49 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
You can look at my driveway (IMG:style_emoticons/default/biggrin.gif)
Exxon Valdez kinda leak. No smoke, but I didn't want to get under the car without a hazmat suit on. Pushrod tube(s)? How's it running with more advance?? |
bd1308 |
Oct 17 2006, 06:51 PM
ahem, oil pressure switch. You'll *SEE* it leaking.
Carlitos Way |
Oct 18 2006, 09:20 AM
I'll try to get under it tomorrow. Been busy doin' the family thang the last couple of days... and my cardboard box in the garage is ready for a replacement (read: It's already soaked in oil).
Heeltoe914 |
Oct 18 2006, 10:29 AM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Well... my engine is REALLY leaking oil right now. I'm talking about a quart of oil per 3/4 tank. Howard thinks it might be blow by. Can anyone tell me how to do a leakdown test and or any other test I might run to figure out where the oil is coming from? I will give you a hand on checking the car out. Lets get it over to my lift so we can see where its coming from. I instruct you do the work. 818 266 7774 |
Carlitos Way |
Oct 18 2006, 12:14 PM
That sounds like a great idea. I really appreciate the offer. Would you be available some time this weekend?
Heeltoe914 |
Oct 18 2006, 12:45 PM
I should be working in the 914barn Fri, & Sat, Unless girlfriend has another idea. call me 818 266 7774
Lo-Fi Version | Time is now: 2nd January 2025 - 11:04 AM |
