Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Happens to all of us.. (IMG:style_emoticons/default/dry.gif)
a 944 isn't much better as if the timing belt lets go.....ya are toasted too with bent valves and all. |
tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
I finally pulled my motor this morning and stripped it down. I pulled the plugs and noticed some damage to a time-sert. I did not have time to pull the heads off today, hopefully I'll get to that tommorow.
I am attaching a picture of my spark plug that still has the damaged time-sert on it. Any thoughs on why the time-sert got damaged? I think the cylinder had struck it and perhaps this lead to the seizure of my motor. (IMG:http://i13.photobucket.com/albums/a276/tradisrad/DSCN4011.jpg) (IMG:http://i13.photobucket.com/albums/a276/tradisrad/DSCN4008.jpg) |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Looks like it has melted, not impact damage. Excessive heat?
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
You had head work done and got it back with a time-sert? I'd expect the holes to be welded up and redrilled, especially on a 2 liter. Who did the work? Any warranty?
tradisrad |
tradisrad |
You had head work done and got it back with a time-sert? I'd expect the holes to be welded up and redrilled, especially on a 2 liter. Who did the work? Any warranty? the head had a heli-coil in it that came out on me, the fellow who did my head work suggest I put in the time-sert, so I did. I dont think I have a warranty with this one |
TheCabinetmaker |
Looks like it has melted, not impact damage. Excessive heat? I think the time-sert is steel, so would the head not melt first? Well yes, but you haven't pulled the head yet to check for damage, right? I'll bet there is some. How could anything make impact with the timesert and not destroy the end of the plug? |
dmenche914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 ![]() |
Looks like the spark was being made between the insert, and the plug, or insert, and head. Molten insert metal dropped into the cylinder, adn seized the motor. Guess we will know more when the head comes off. other than that, maybe teh insert extended too far into the head, and became a hot spot. yuck!!!!
tradisrad |
Looks like it has melted, not impact damage. Excessive heat? I think the time-sert is steel, so would the head not melt first? Well yes, but you haven't pulled the head yet to check for damage, right? I'll bet there is some. How could anything make impact with the timesert and not destroy the end of the plug? good point... I'll have the heads off soon and will post back with my findings. the wife is rushing me out of the house right now. |
tradisrad |
The motor is apart and I found the problem.
Seems that a rod bearing got destroyed. Looks like the engine needs the bottom end rebuilt. (IMG:http://i13.photobucket.com/albums/a276/tradisrad/DSCN4027-1.jpg) |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
check your crank, hang it up on something suspended, and whack it softly with a hammer, if it rings its good, if you hear a dull thud its toast.
Lo-Fi Version | Time is now: 1st July 2024 - 12:22 PM |
