> Engine Stumbles When Cold
73jef74
post Oct 24 2006, 04:22 PM
73 2.0 stumbles when cold. Is worse at lower RPMs. Will not pull smoothly from 2000 RPM when cold. Does not like to stay running when first starting. These conditions improve as engine is warmed up. Any suggestions?
mihai914
post Oct 24 2006, 04:29 PM
How does it idle when cold, RPM wise?
73jef74
post Oct 24 2006, 05:16 PM
The idle when cold, once you get it running, seems OK.
Marlow
post Oct 24 2006, 06:18 PM
What kind of rpm's are you seeing when the engine is cold?
73jef74
post Oct 24 2006, 08:12 PM
About 900 RPM.
So.Cal.914
post Oct 24 2006, 08:18 PM
"...And it has a front trunk too."
Simple answer:
Let it warm up before you drive it.
Bleyseng
post Oct 25 2006, 07:50 AM
Aircooled Baby!
PB Blaster the crap outta the AAR valve to free it up. Check that its opening up all the way and closed after 5 min or so after running the motor. Idle should be cold 1200-1800 rpms
R U running the right CHT? 017 # with a 270 ohm resistor inline with it. Otherwise its not going to idle right due to too lean a idle mix.
Get a tune up, all the right parts, valves adjusted, and then drive the car for 15-20 minutes so its hot. Then adjust the idle to 950rpm with the knob on the ECU about where the factory notch is and using the air bleed.
Now you are set up close to good and when it starts up cold it should idle at 1500 bout and then slowly go down to 950. There will be a period of light hunting until is fully warm. (IMG:style_emoticons/default/shocked[1].gif)
- Lo-Fi Version Time is now: 21st December 2024 - 08:58 AM
