> OT. Stereo Electronics Gurus, My home stereo has a buzz
Brett W
post Oct 26 2006, 08:22 PM
When I turn my stereo I get a low level hum/buzz. How do I get rid of it? My system is a few year old Pioneer rack system. Nothing special.
jimtab
post Oct 26 2006, 09:07 PM
mine did that when my ground on the turntable was screwed up...after that ?????
McMark
post Oct 26 2006, 09:12 PM
914 Freak!
Ground loop problem. Search for ground loop on google.
ahdoman
post Oct 26 2006, 09:33 PM
It's phonetic...Ah-D-O-Man (Audioman)
Ground loops can be a pain to trace. There are two most common problems that create the hum besides ground loops. The first is wall warts and other power supplies. Don't run your power cables bunched up with your line level (hopefully shielded) cables. Second is make sure you are not using unshielded cable for your component interconnect. E.G. use shielded between your CD player and tuner / amp. Make sure you only use speaker cable for speakers.
So.Cal.914
post Oct 26 2006, 09:58 PM
"...And it has a front trunk too."
I had a capacitor go bad on my BGW 750-A rack mount amp and it developed a hum,
replaced it and it's now clear as a bell.
- Lo-Fi Version Time is now: 15th January 2025 - 05:11 AM
