Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
This is a soild 2:01 with a passenger.
I did a 2:00 solo. 10-6-06 I shaved 6 seconds from my previous track day here (IMG:style_emoticons/default/clap56.gif) KT |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
link no workie (IMG:style_emoticons/default/confused24.gif)
johannes |
Club Porsche 914 France President ![]() ![]() ![]() ![]() Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France ![]() |
Just add the .com at the right place and it will work http://www.mindovermotorsports.com/video/Sears10_6_06.wmv (IMG:style_emoticons/default/burnout.gif) |
drgchapman |
Current Stable ![]() ![]() ![]() Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest ![]() |
I'm screaming as you go through the carosel.........where's the screaming smilie?
Trekkor knows Sears. Showed me the way to 2:01 with him in the passenger seat last Sunday. |
KenH |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 ![]() |
Good run.
So do you think the Hoosiers are better than the 710s?? Ken |
Trekkor |
I think the Hoosiers may be.
I know my fastest lap came on them...6 seconds better. I wasn't driving as hard then either. Link fixed... KT |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
Thanks for the video ride Trekk!
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
nice driving and your 914 is in all its glory - you guys make a great team.
nice to see a 914 doing what it is supposed to be doing - IMHO ! Jim |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Looks good Trek!
On that lap I could only see 1-2 spots where you could have been on the gas sooner or tracked out farther. Very smooth! Very good!! I wasnt in the car (3 people??..lol) but it looks like you could have pushed it harder in the carousel and used less brake going into the 11. B |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,799 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
(IMG:style_emoticons/default/piratenanner.gif) Congrats, You are smokin' fast. Are you coming back 11/13 or therabouts?
grantsfo |
Arrrrhhhh! ![]() ![]() ![]() ![]() Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None ![]() |
Trekkor you definitely know your way around Infineon. Its funny comparing your video to mine. Your short gears allow you to shift about twice as much as I was. My engine also likes to pull from 3500 RPM to about 6000 RPM. So your car is screaming through the gears while mine sounds like I'm out on a Sunday drive. (IMG:style_emoticons/default/biggrin.gif)
Trekkor |
thanks!!
I'll be there for the season closer on 11/12 with TMR KT |
Trekkor |
QUOTE but it looks like you could have pushed it harder in the carousel and used less brake going into the 11. yes, when I hit it just right in 6, I put both right wheels directly on the last ten feet of the rumble strip on exit. I'm scared to find any more time in 1, 10 or 11. (IMG:style_emoticons/default/unsure.gif) KT |
Brad Roberts |
I viewed it a few more times (IMG:style_emoticons/default/biggrin.gif)
Here is my take: You are driving to the exit in some of the turns. You are are not at the limit of the tires. Not drifting the car to the exit berms, but driving it out there. Instructors teach you: "late is safe" referring to "late apex" try less brake and more speed. Then try backing the apex up. You are ultra smooth (which is impossible to teach..and you didnt have when you started all this) but sometimes "smooth" isnt all that. Sometimes it take an "abrupt" change of balance in the car for certain corners. B |
TravisNeff |
How did the splitter go?
grantsfo |
QUOTE but it looks like you could have pushed it harder in the carousel and used less brake going into the 11. yes, when I hit it just right in 6, I put both right wheels directly on the last ten feet of the rumble strip on exit. I'm scared to find any more time in 1, 10 or 11. (IMG:style_emoticons/default/unsure.gif) KT Bet you could find more time from 7 to 10. You are ripping into and out of the Carousel. On 11 the Spec Miata guys cut the corner over the paint. I was afriad to try it at first, but it was quicker and I didnt lose traction as much as I thought I would. |
Trekkor |
One of my instructors holds the lap record at Sears in his SCCA class and was following me.
He said he was as fast or faster than me in every turn *except* the Carousel. He said I brake way later than he can and carry way more speed out of the turn. This was surprising to me. KT |
Trekkor |
Racing916 |
Member ![]() ![]() Group: Members Posts: 341 Joined: 16-October 04 From: Binghamton, NY Member No.: 2,959 Region Association: North East States ![]() |
Trekkor,
Nice Lines, your car sounds great. Nothing better than the sound of a "six". You can tell that you are carying alot more speed than your previous videos at Sears. Steve |
Jeroen |
forgive my ignorance, but which one is "carousel"
is it the one before the "thumbs up" ? |
Lo-Fi Version | Time is now: 2nd April 2025 - 01:38 AM |
