Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
drew365 |
These are the good old days! ![]() ![]() ![]() ![]() Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 ![]() |
Very nice run Trekkor. It's amazing how much you can learn about your driving by watching video. I'm glad I finally put a camera in my car.
Thorshammer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 749 Joined: 11-November 03 Member No.: 1,335 ![]() |
Nice run, I bet there is 2 plus seconds with some gear ratio changes. Not sure if this is your street car or DE/race only. It is true what BRad says about backing the APEX up, this allows for a longer run down the striaght away following the turn. I would say, real good. Nice and smooth. Erik |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Trek,
When I visit a track in a new car (or my first time).. I start late on the "scary" corners and then start backing up the apexes each lap around until I run out of "track out" and just about hang a tire off. Not all corners will be late and not all corners will be early, but if you learn to approach corners early and late.. you will learn quickly how to pass people on different lines but maintain your speed. B |
Trekkor |
Hmmm. I see.
I had a little more room to track out in every corner except maybe : 3a, 4 and 11. I've hit each turn to the absolute limit for me many times. It's nailing them all in one lap. "The perfect lap"... KT |
Trekkor |
QUOTE I bet there is 2 plus seconds with some gear ratio changes. Not sure if this is your street car or DE/race only. Mainly DE and a/x. It's still street legal and insured but that may change over the winter. I'm running the MSX gear set and I like that quite a bit. KT |
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
trekkor- I would like to see you add some still pics of your car to your blog - jim
Trekkor |
trekkor- I would like to see you add some still pics of your car to your blog - jim OK Attached image(s) ![]() |
Trekkor |
weekend (IMG:style_emoticons/default/icon_bump.gif)
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
See, we all do a little shameless self promotion! (IMG:style_emoticons/default/tongue.gif) (IMG:style_emoticons/default/tongue.gif)
(IMG:style_emoticons/default/beerchug.gif) |
Trekkor |
It's my "watch me stumble around the track" infomercial. (IMG:style_emoticons/default/laugh.gif)
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,132 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
forgive my ignorance, but which one is "carousel" is it the one before the "thumbs up" ? It's turn 6, the 180-degree on-camber left-hander that drops you about 4 stories. Track map of Sears Point (older map, but I think this is the configuration that Trek was running) -- (IMG:http://www.na-motorsports.com/Tracks/CA/images/sears-point.gif) --DD |
Trekkor |
Another
Lo-Fi Version | Time is now: 2nd April 2025 - 11:38 PM |
