> Alignment, done !
J P Stein
post Mar 6 2003, 03:19 PM
Irrelevant old fart
Hey, we went out in the rain today.
Fortunately the alignment chop is only a half mile away.
Here's what we gots:
Camber R/F -1.99 L/F -1.99
R/R -2.3 L/R -2.25
Caster R/F 5.08 L/F 5.31
1/16 toe in at both ends.
Pulled another 3mm shim from each side in the rear.
I"d like to get more caster, but I'd have to do some more grinding around the strut mounts. Maybe next winter.
A short drive shows the car to be VERY responsive.
The ride is....er....firm....but not as bad as I thought it would be. Vracers really suck in the wet.
Now if the weather would cooperate, we can go play Sunday. It ain't lookin' good, tho.
J P Stein   Alignment   Mar 6 2003, 03:19 PM
ChrisReale   I thgought you were shooting for 5 degrees of neg ...   Mar 6 2003, 03:32 PM
Dave_Darling   Those things are a digital level with a fixture to...   Mar 6 2003, 05:21 PM
Jeroen   Hey JP, Why in heavens name did you go for toe-in...   Mar 6 2003, 06:25 PM
J P Stein   Cause I screwed up (thanx for asking). I forgot wh...   Mar 6 2003, 09:29 PM
campbellcj   Congrats on getting 'er back together JP. I t...   Mar 6 2003, 10:03 PM
Dave_Darling   It's not really twitchy, you just have to keep...   Mar 6 2003, 10:24 PM
Jeroen   ...   Mar 7 2003, 05:54 AM
J P Stein   Jeroen: Without your mentoring I wouldn't eve...   Mar 7 2003, 02:03 PM
Jeroen   Hey JP, I'm not gonna give you any driving ti...   Mar 7 2003, 08:35 PM
Jeroen   BTW, since it looks like you made it to your scedu...   Mar 7 2003, 08:40 PM
Sammy   onced you get a good alignment, toe changes are ea...   Mar 7 2003, 09:12 PM
J P Stein   Jeroen: AX is kinda like sex. I knew I wuz gonna l...   Mar 8 2003, 02:36 AM
Jeroen   Hey JP, It's not that I never AX-ed before ;...   Mar 8 2003, 06:48 AM
Sammy   I gots my first of the year AX/TT next sunday. I...   Mar 8 2003, 05:44 PM
Aaron Cox   about how much does it cost to have your whole car...   Mar 8 2003, 05:51 PM
Dave_Darling   The local tire store should be able to set the fro...   Mar 8 2003, 06:11 PM
J P Stein   The guy that does mine is a suspension/brakes only...   Mar 8 2003, 06:31 PM
Aaron Cox   Bagged out? i am ready to install my rear springs ...   Mar 9 2003, 01:27 PM
boxstr   First thing you need to find is a shop that can do...   Mar 9 2003, 02:01 PM
- Lo-Fi Version Time is now: 29th April 2025 - 01:15 PM
