Rear suspension redesign, Optimizing a semi-trailing arm suspension |
groot |
Nov 27 2006, 05:39 PM
Dis member Group: Members Posts: 897 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
Good work!!!
I'm bound by the rule book and have to maintain my trailing arm design, so a setup like that isn't part of my plan. I am running my toe link forward. It will be more clear once I get the chassis side complete... but that will have to wait until I get back home.... Fun in the sun!!!!! |
race914 |
Nov 28 2006, 05:45 PM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
Brad Roberts |
Nov 28 2006, 06:16 PM
Ha ha Greg!
I just tracked his site down again over this past weekend to see what he was working on! The guy is amazing. More talent than I will ever have (IMG:style_emoticons/default/smile.gif) B |
edgetoo |
Dec 2 2006, 08:47 PM
Newbie Group: Members Posts: 25 Joined: 26-October 03 From: Rockland, MA Member No.: 1,279 |
Ha ha Greg! I just tracked his site down again over this past weekend to see what he was working on! The guy is amazing. More talent than I will ever have (IMG:style_emoticons/default/smile.gif) B Hi Kevin, I am the current owner of Blakes' car and motor. Last season we sat down and tried to optimise the setup. Rear rideheight was lowered about 2 in. (there is now a signiffant dent in the x-pipe above the axel and the cross-over pipe under the bell housing is worn thin.) The front and rear have been bump steered and cross weighted. The rear camber is about as Blake ran it with minimum toe in and toe change. (trailing arm bushes are by CFW as are the camber plates.) (Front struts are by CFW) Rear Piviots points are stock.) Motor has about 12 races on it. Net Results were 2 poles under the lap record, 1 lap record, and 1 win. (I'll discuss the Trans- HE- on the other thread) Ed Givler |
ChrisFoley |
Dec 5 2006, 04:34 PM
I am Tangerine Racing Group: Members Posts: 7,976 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
... (trailing arm bushes are by CFW as are the camber plates.) (Front struts are by CFW) ... Ed Givler Hmm, CFW. That would be Chris Foley Welding I guess. (IMG:style_emoticons/default/laugh.gif) |
edgetoo |
Dec 6 2006, 12:46 PM
picky, picky!!
Thank goodness that Chris' fabrication is much better than my spelling! Ed |
Lo-Fi Version | Time is now: 18th January 2025 - 04:12 AM |
