Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Change the gears.
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
taller 5th....
the ratio of a gear is X:Y. you want something 'overdive' under 1:1 ratio... (less tan 1.00) so if yo take a an H gear... 19:32... and you flip the ratio (32:19) what is your outcome? way lower than a 1:1 ratio |
jwalters |
Sooo Close....... ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe ![]() |
What would you think the overall spacing would be (assuming a stock geared tranny) by using a 26" dia. tire.
Kinda like the 2005 caddie down the street from me with 23's on it and 30 series.... That thing has more ground clearance than a hummer........ (IMG:style_emoticons/default/unsure.gif) |
jwalters |
taller 5th.... the ratio of a gear is X:Y. you want something 'overdive' under 1:1 ratio... (less tan 1.00) so if yo take a an H gear... 19:32... and you flip the ratio (32:19) what is your outcome? way lower than a 1:1 ratio Stock tranny has an "H" gear?? - or is that the one everybody covets?? |
Dr Evil |
H gear from a 912 tranny
Aaron Cox |
read the posts...
GREY outline is stock 914 gears.... mike... stop selling our sources out! LOL |
jwalters |
What would you think the overall spacing would be (assuming a stock geared tranny) by using a 26" dia. tire. Kinda like the 2005 caddie down the street from me with 23's on it and 30 series.... That thing has more ground clearance than a hummer........ (IMG:style_emoticons/default/unsure.gif) Oh, the reason I ask this is beacuse the suspension could be lowered enough in the rear to not have ass high look - Also, back in my days street rods and sports car addicts had the need to put on larger diameter rears and keep small diameter fronts ( like the 70's - 80's LOLA'S) This actually looks really, really good onclassic sports cars!! Think about it: matching rims with 15's on front and 21 -22's on the back and a level chassis - looks really cool and would help some with overall ratio I know - just by how much I do not--- |
jwalters |
jwalters |
jwalters |
914fan |
Member ![]() ![]() Group: Members Posts: 118 Joined: 17-January 05 From: Fountain Valley CA Member No.: 3,460 ![]() |
Has someone mentioned or can it be done?
Flip "K or J" gear for a .7 or .677 in fifth. only slightly less rpm. Less rpm = less cooling. However the cars were designed for a 55mph speed limit. In 4th thats a little over 3k and 5th is 2.5k. 80 is almost 5K in 4th and 4K in 5th. I would like 2-3 hundred rpm less at 80 if it were resonably possible. If you were running a larger, stronger, more efficient motor, that should not be a problem. If you built something with "nikies" and modern FI it could probably be just fine with even lower rpms. Just my 2 cents |
Aaron Cox |
you can only flip 3rds to 5th's.... and 5ths to thirds....
or if you have a 904 mainshafts.. 2nd's to 4ths' and 4ths to seconds... now you have to find the gears.... |
Dr Evil |
Has someone mentioned or can it be done? Flip "K or J" gear for a .7 or .677 in fifth. only slightly less rpm. Less rpm = less cooling. However the cars were designed for a 55mph speed limit. In 4th thats a little over 3k and 5th is 2.5k. 80 is almost 5K in 4th and 4K in 5th. I would like 2-3 hundred rpm less at 80 if it were resonably possible. If you were running a larger, stronger, more efficient motor, that should not be a problem. If you built something with "nikies" and modern FI it could probably be just fine with even lower rpms. Just my 2 cents K and J are second gears and would only be possible if you could find them and a 904 shaft to use them with ($$$$). Your car works harder at higher speeds (thats why it takes more gas usually) so you will make more heat. If you want to put nikies on and do enhancements then you change the whole conversation. |
bernbomb914 |
one of the oldest Farts on this board ![]() ![]() ![]() Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 ![]() ![]() |
could you build a trans with this ratio
C I R Y HD I have all but the I ratio's in my booty and would like to build this to go with my 78x104 engine. Bernie |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
Aaron Cox |
could you build a trans with this ratio C I R Y HD I have all but the I ratio's in my booty and would like to build this to go with my 78x104 engine. Bernie you would need a 904 splined mainshaft to put an I on there.... (or you would have to cut old gear off and weld on a new one...ask brant) |
bernbomb914 |
what is close to I that would fit or what would you recomend in place of I
Bernie |
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
bondo |
Dr Evil |
Ya, but he was just asking about swapping in a K or a J and those require the same thing as an H (as stated, 904 shaft). It looks as if I need to get a picture laden thread about what a swap is and why it can be a bitch started some time in the near future. (IMG:style_emoticons/default/idea.gif) Its not like I dont have a bunch of parts (IMG:style_emoticons/default/biggrin.gif)
Scott, your stack is on my front stoop. I'll gat a look at it as soon as possibel so we can start spending your money on replacement parts (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 02:20 PM |
