Boojum |
Member ![]() ![]() Group: Members Posts: 95 Joined: 31-July 06 From: Denver, CO Member No.: 6,550 ![]() |
Awesome job, and great color too! If my handiwork comes out looking half as nice as this when it comes time for me to do some of this I'll be greatly pleased.
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
There is German in your ancestry... somewhere.
wow |
JPB |
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 ![]() |
Wow nice work and looks fantastic! (IMG:style_emoticons/default/smilie_pokal.gif)
(IMG:style_emoticons/default/popcorn[1].gif) Crap I'm lazy. |
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,841 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
Wow, thats very impressive (IMG:style_emoticons/default/clap56.gif)
I agree with Boojum; if mine comes out half as nice I'll be very pleased. If you don't mind, what brands of paint did you use? |
thomasotten |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,565 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 ![]() |
There is German in your ancestry... somewhere. wow Yep, 100% German, mom and dad came to the U.S. back in the 60's. (IMG:style_emoticons/default/smilie_flagge6.gif) The paint is Dupont Chromabase. I way overestimated what I would need. MY compressor was a sears 33 Gal. Attached image(s) ![]() |
thomasotten |
Thanks, for the compliments, everyone. Yes, at this point the car looked pretty good. But, as this picture shows, the clear coat has far too much ORANGE PEEL.
But never fear, we're only halfway done with our paint job at this point....stay tuned... Attached image(s) ![]() |
TINCAN914 |
Summer's Commin... ![]() ![]() ![]() ![]() Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains ![]() |
Looks great!!!
Nice work Thomas!! (IMG:style_emoticons/default/beerchug.gif) |
HeloMech |
Go Ahead, Get Pistoph! ![]() ![]() ![]() Group: Members Posts: 691 Joined: 31-August 05 From: Roy, WA Member No.: 4,718 Region Association: Southern California ![]() |
I bet these pics don't even do it justice. And orange peel? pshaw... wet sanding is your friend... that's gonna be glass...
Yay... |
lybones |
Member ![]() ![]() Group: Members Posts: 159 Joined: 26-April 05 From: Garden Grove, CA Member No.: 3,986 ![]() |
That's gonna be one jaw dropping home paint job. Outstanding work.
Borderline |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California ![]() |
Looks great! (IMG:style_emoticons/default/aktion035.gif) I'm at the point where I'm just about ready to put on my first coat of primer. Did your Craftsman 33 gallon compressor keep up with the gun? I've been reading all I can on painting and they say that any pressure drop while painting can effect the performance of the gun. Sure looks nice. Wish I was that far along.
sj914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 ![]() |
thomasotten |
Yes sir, Devilbiss Plus. The compressor kept up just fine. You can paint several panels without it coming on somtimes. |
thomasotten |
Ok, so at this point I had a freshly painted car with three coats of clear on it. What could be done here is to buff out the car and be done with it, and it would look great. But I decided that I wanted an even better paint job. If you search on the internet you will find that the hot-rodders and custom paint guys have a way for making a deep clear glass-like paint job. Basically, what you do is you sand the entire car down again until the clear is perfectly flat again. Then, you apply MORE CLEAR!
The more clear you put on the car, the less-flat the surface gets. That's because each coat of clear introduces a bit of orange peel each time. So what you have to do is cut the clear down - block sand it with 600 grit paper and prepare to reshoot more clear on to the car. The common objections to this technique is that you will be able to see the scratches left by the 600 grit paper through the clear. This is not true, and there is a guy on the Autobody forum that even goes as far as 320 grit. But 600 is enough to provide a pretty good mechanical bond between your clear layers. So off I went sanding again.... Attached image(s) ![]() ![]() |
thomasotten |
You can really see the orange peel and dust nibs when you start sanding. With three coats of clear, you can sand and sand without much fear of sanding through to the base. Except around edges, where one should be very carefull.
thomasotten |
Sanding the car down again also allowed me to eliminate the ridge that develops when you apply stripes. This door had to be agressivly sanded to get the ridge line eliminated.
thomasotten |
So this is how everything looked when cut down with 600. FLAT!
Attached image(s) ![]() ![]() ![]() |
thomasotten |
More pics later...
1bad914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 ![]() |
Wow, sand and re-clear seems extreme, I have always had great luck wet sanding the clear from 1000 thru 2500 grit and then buffing it out. Interesting, I might give that a try once. I can see that it might add depth, but I don't see that it will make it flatter, if the OP and nibs are gone then it would be flat...hmmmm I have to think about that.
thomasotten |
Wow, sand and re-clear seems extreme, I have always had great luck wet sanding the clear from 1000 thru 2500 grit and then buffing it out. Interesting, I might give that a try once. I can see that it might add depth, but I don't see that it will make it flatter, if the OP and nibs are gone then it would be flat...hmmmm I have to think about that. If your interested, check out these two links to see a similar procedure done on a cool 356 Speedster... 356 - Step By Step 356 - Finished Car -- Sweet |
biosurfer1 |
Teener fo Life! ![]() ![]() ![]() ![]() Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California ![]() |
wow, good write up...i can't believe he was so calm about the guy hitting him, after all that work, if someone hit me only 2 months after i finished i would have gone crazy!
Lo-Fi Version | Time is now: 3rd April 2025 - 12:55 PM |
