Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
^^^ Looks like the area being reinforced in Eric's photos didn't really need it...
(IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
JPB |
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 ![]() |
Did ya do a torsion test on this gusset setup?
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
QUOTE Looks like the area being reinforced in Eric's photos didn't really need it... Well, even a guy like you can see what the gussets did for that arm (IMG:style_emoticons/default/biggrin.gif) Seriously, the gussets aren't to prevent mass failure as in John Rogers case or the arm that Brett is showing. They are there to prevent flex while driving the car. This was part of the conversation I had with Erik Madsen, that area does flex. I felt that even the simple gusset arrangement I've added will help reduce that flex tremendously... that's what gussets are for. I think I've accomplished my goal. A control arm that is 40-50% more ridgid than stock without the weight penalty. QUOTE Note to self, don't trust Eric's scale Note to Steve... don't you have a running car to purchase to take to an event, tear apart so you can't make the event, rebuild then sell??? (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/tongue.gif) Jim (Stratplayer) was just here and witnessed the scale first hand... so THERE! (IMG:style_emoticons/default/bootyshake.gif) |
Eric_Shea |
QUOTE Here is a good example, albeit extreme, of what happens to an swing arm when radically loaded through the tire contact patch Brett, just the tire contact patch caused that control arm to bend down at a 45 deg angle? Or, was it the wheel coming in contact with a curb. That would be some serious grippage... (IMG:style_emoticons/default/ohmy.gif) |
LvSteveH |
I put the Poor in Porsche ![]() ![]() ![]() Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 ![]() |
Note to Steve... don't you have a running car to purchase to take to an event, tear apart so you can't make the event, rebuild then sell??? (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/tongue.gif) Jim (Stratplayer) was just here and witnessed the scale first hand... so THERE! (IMG:style_emoticons/default/bootyshake.gif) Actually, the car's back running again, although still on jackstands, and I'll never be able to sell it, I'm in too deep. Should be pretty neat when it's finished though. I'd like to have it going for spring. |
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
Since my big wing on the back generates 10K lbs of, Of course it was through the tire contact patch. You ought to see how powerful my car is.
Actually that was a curb applied through the lower sidewall, upon impact. Yes it was pretty radical example but the arm didn't really bend in laterally, it actually twist. |
Eric_Shea |
Stratplayer was gracious enough to apply the powdercoating. (IMG:style_emoticons/default/smilie_pokal.gif)
I'm happy. Here's my line of thought. 1. From measurements I've seen these should be 50% stiffer than stock. 2. There is literally no measurable weight penalty. 3. Could they be stiffer? Yes. 4. Should they be stiffer? There's a lot of arguments against that. This and a decent set of bushings will net a rear control arm assembly that is better than 90% of the 914's that are currently out there. Here's a few pics. I've yet to press out the old bearings (I left them in to powdercoat them). Attached image(s) ![]() ![]() |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
sweet!
what if you ran one at a 45 degree angle.. inner right bottom to upper left top etc? oh wait... too much geometry LOL looks good dude |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
Cool, idea stolen for mine.
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
96.75% of all statistics are made up on teh spot
what measurement was made to determine percent of improvement? what club member did the rear arm flex measurement fixture? I remember a thread about this |
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
Chris Foley was in that other thread.
He apparently has figured out how to strengthen the arm with very little weight. Now where the hell is that thread...??? I Think he opened the arm up and boxed it internally. Then welded a patch over it. Thats my memory of that thread. Could be wrong. I can't find it. C |
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
Its only on the 914club now :shrug:
Since Brad has no pictures up they are gone though. http://www.914club.com/bbs2/index.php?show...873&hl=weak |
JPB |
Any extra stiffyness is good stiffyness. Thanks for sharing and will probably hole saw a couple of tubes in on mine some time as well as the goossetes. (IMG:style_emoticons/default/beer.gif)
roadster fan |
Project Frankenstein !!!!!!!! ![]() ![]() ![]() Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California ![]() |
IIRC, Chris Foley cut the arm in half perpendicularly. He then welded a piece of 1/8" plate between the two. I think he said the kerf on the cut was about 1/16" so he only made the arm 1/16" longer by adding the plate. I thought I had the pics but couldn't locate them....sorry (IMG:style_emoticons/default/dry.gif)
Jim |
roadster fan |
I think this is how he did it.... ![]() |
Rusty |
Wanted: Engine case GA003709 ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 7,943 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch ![]() ![]() ![]() |
Its only on the 914club now :shrug: Since Brad has no pictures up they are gone though. http://www.914club.com/bbs2/index.php?show...873&hl=weak Older threads are in the same place... updated domain name. http://www.914world.com/bbs2/index.php?showtopic=42873 Hope this helps, Rusty (IMG:style_emoticons/default/smoke.gif) |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
All the pictures had been removed from that thread by the poster.
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
I used Aaron's idea of supports on 45 degree angles. Used two 3/8 inch rods crossed in 2 places.
Any ideas if this will help the flex? Spoke Attached image(s) ![]() ![]() |
JPB |
For that to work really good, one would have to weld the two rods together where they cross in the center.
If we cut the box lengthways through the center and added a 1/8th plate that goes from one side to the other in the same plane as the bolt welded solid on all the way around, it would make a huge increase in stiffness. If the bolted end had a flare like a single gusset similar as above but just down the center and welded solid, it would be amazing. |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Its only on the 914club now :shrug: chris foley deleted all his posts here after the split ... (IMG:style_emoticons/default/dry.gif) Andy |
Lo-Fi Version | Time is now: 25th June 2024 - 04:34 PM |
