My Weekend Project, Removing the Backpad |
jgara962 |
Jan 28 2007, 06:43 PM
Yo, this is how I roll Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California |
Well, here is an update to what has turned into my multi weekend project (IMG:style_emoticons/default/dry.gif) . The Dynamat is in. It ended up taking two wedge packs to cover the area behind each seat. I'm already in for $100 in Dynamat, so I decided not to do the center area.
A tip for anyone planning on doing this. It is recommended to leave the Dynamat in the sun for 15 minutes before you apply it to make it easier to work with. Since we didn't have any sun today, I used a hair dryer. I heated up a little section at a time and used the wooden roller to press it on. Now back into the garage to put the driver's side seat and harness in, and the passenger side seat belt. Has anyone heard from Morph lately? (IMG:style_emoticons/default/confused24.gif) We e-mailed once a couple of weeks ago about the price of a firewall carpet kit, and I've sent two e-mails and a PM over the past couple of weeks with no response. Attached image(s) |
dgw |
Jan 28 2007, 07:17 PM
Dennis Winter Group: Members Posts: 553 Joined: 7-January 03 From: Santa Cruz Mountains Member No.: 106 Region Association: Northern California |
Thats a lot of work John.
Use the 3M stuff when you get to cleaning up the other side of the firewall. I've replaced a lot of door seals, and the 3M stuff is magic. |
jgara962 |
Jan 28 2007, 08:09 PM
Thats a lot of work John. Use the 3M stuff when you get to cleaning up the other side of the firewall. I've replaced a lot of door seals, and the 3M stuff is magic. Hey Dennis (IMG:style_emoticons/default/wavey.gif) Once she's done I'll send you a couple of pictures. |
jgara962 |
Jan 28 2007, 08:11 PM
Sooooo, does anyone know how to get the seat belt reel to unlock? I can't put it back on until I get some slack pulled out of the reel, but it is locked up and not letting me pull.
Jeffs9146 |
Jan 28 2007, 08:17 PM
Sooooo, does anyone know how to get the seat belt reel to unlock? I can't put it back on until I get some slack pulled out of the reel, but it is locked up and not letting me pull. I think you need to hold it at the neutral posission and attempt. It has a lock out pengulium that sets into place when the brakes are applied! Jeff |
boxstr |
Jan 28 2007, 08:41 PM
You might as well do the center area or you havent really done that much good by just doing the sides behind the seats. You really need to cover as much area as possible. You will still have noise infiltration in the center unless covered.
Next time I would recommend using Phat Mat. One normal size roll would be enough to cover all of the back area with more left over. CCLINPHATMAT |
swood |
Jan 28 2007, 10:51 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Do you really have to get all that factory glue off the rear wall in order to apply the sound deadening pad? Seems like cleaning it real well with mineral spirits would at least get the oil off and make it clean enough for a good bond.
But what do I know. |
highways |
Jan 29 2007, 03:29 AM
Senior Member Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 |
You might as well do the center area or you havent really done that much good by just doing the sides behind the seats. You really need to cover as much area as possible. You will still have noise infiltration in the center unless covered. Next time I would recommend using Phat Mat. One normal size roll would be enough to cover all of the back area with more left over. CCLINPHATMAT Got a link for the Phat Mat's? I looked and only found this... derogatory 914 joke? Or just the way you do it oregon? May the reader decide... (IMG:style_emoticons/default/golfer.gif) |
MoveQik |
Jan 29 2007, 08:46 AM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
I would do the whole thing. I did mine and I am happy with it. You can also use perlon as opposed to carpeting on the back wall. That is what I did and I think it turned out ok.
I did have a strip of carpeting stitched up for the bottom 6" of the firewall(the part that isn't covered in the pic. Good luck! Attached image(s) |
boxstr |
Jan 29 2007, 11:12 AM
I spelled it the way a bro would it should be FAT check this out
http://www.fatmat.com/ Pic shows my 32 GFord highboy roadster that I fatmatted the floors, front and rear, and all of the sides. It made a HUGE difference. CCLINPRAISETHELOWERED Attached image(s) |
jgara962 |
Feb 21 2007, 11:19 PM
IT'S DONE!!!! (IMG:style_emoticons/default/piratenanner.gif)
I decided to go all out and change the interior color while I was at it. I had the rear firewall done in a charcoal color, and replaced the tan carpet with a charcoal color as well. I also used Dupli Color vinyl paint to paint my door panels black to match everything which some of you might have seen in my other thread. A HUGE thank you to McMark for hooking me up and helping me out on this project - I really appreciate it. (IMG:style_emoticons/default/clap56.gif) (IMG:style_emoticons/default/beerchug.gif) Now all I need is some sunny weather to take her out and show her off! (IMG:style_emoticons/default/driving-girl.gif) Attached image(s) |
ppickerell |
Feb 21 2007, 11:31 PM
914 addicted Group: Members Posts: 1,679 Joined: 14-October 03 From: Pleasanton, CA. Member No.: 1,246 |
IT'S DONE!!!! (IMG:style_emoticons/default/piratenanner.gif) I decided to go all out and change the interior color while I was at it. I had the rear firewall done in a charcoal color, and replaced the tan carpet with a charcoal color as well. I also used Dupli Color vinyl paint to paint my door panels black to match everything which some of you might have seen in my other thread. A HUGE thank you to McMark for hooking me up and helping me out on this project - I really appreciate it. (IMG:style_emoticons/default/clap56.gif) (IMG:style_emoticons/default/beerchug.gif) Now all I need is some sunny weather to take her out and show her off! (IMG:style_emoticons/default/driving-girl.gif) Looking good, are those Stefan's seats? |
Brando |
Feb 21 2007, 11:51 PM
Hot damn that's a good lookin' interior.
What kind of seats are those? |
jgara962 |
Feb 22 2007, 10:57 AM
andys |
Feb 22 2007, 11:06 AM
Hot damn that's a good lookin' interior. What kind of seats are those? Thanks. Those are the Corbeau Classic II seats. How's the comfort of those seats? Can you easily access the hand brake lever?Anyone else running them; opinions? Thanks, Andys |
jgara962 |
Feb 22 2007, 01:56 PM
Hot damn that's a good lookin' interior. What kind of seats are those? Thanks. Those are the Corbeau Classic II seats. How's the comfort of those seats? Can you easily access the hand brake lever?Anyone else running them; opinions? Thanks, Andys I like them because their look goes well with the car in my opinion. They have good support and are pretty comfortable except for an oddly placed support bar which you can feel in your upper back. The only other thing is that with the harness going over the lateral support, it doesn't fit as snugly on my lap and tends to ride up a little bit around my stomach. Maybe it's just how I'm built? (IMG:style_emoticons/default/dry.gif) |
Chris Pincetich |
Feb 22 2007, 02:01 PM
Looks great John. You going to Santa Rosa PCA AX March 3? My car is in pieces now, but I hope to get it all together and race (IMG:style_emoticons/default/beerchug.gif) |
KaptKaos |
Feb 22 2007, 02:22 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
How did you handle the seat brackets? They look nice btw!
jgara962 |
Feb 22 2007, 03:12 PM
How did you handle the seat brackets? They look nice btw! I REALLY went back and forth on that one between using the mounting bars that I bought from Corbeau and just mounting the brackets directly to the seats. I ended up mounting the brackets directly to the seats by drilling new holes in them and then using the bolts from the kit. |
andys |
Feb 22 2007, 04:13 PM
John,
I hear tell that the Classic II's sit you about 2" higher in the car than the stock seats resulting in interference with the steering wheel. What's your opinion? Andys |
Lo-Fi Version | Time is now: 26th June 2024 - 08:19 AM |
