Removing Center Console |
GaroldShaffer |
Nov 20 2003, 09:57 AM
You bought another 914? Group: Benefactors Posts: 7,628 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Finally getting back to parting the 74. I am trying to get
the center console out. I have removed the lower dash pad (knee pad?) unbolt, unscrewed everything I can see. Do I need to remove the shifter? If so how, the console is in the way? I know, dumb question but what do you expect, it took me a hour to get the passenger door open. (IMG:style_emoticons/default/laugh.gif) - Garold |
Jeffs9146 |
Nov 20 2003, 10:06 AM
Make sure you have the seats and center box out and it will be a lot easier! Remove the shifter knob and twist the consol. It will work out if you have removed all of the screws and panels!
Jeff |
McMark |
Nov 20 2003, 10:09 AM
There are only three bolts that hold the console in place. Two up under the dash and one back behind the shifter in the U-shaped metal piece. Once those are out, you just push, pull and twist it out. It's one of those situations where there is a magic spot where it comes out without force, but you'll never find the magic spot, except by accident. (IMG:style_emoticons/default/biggrin.gif)
JWest |
Nov 20 2003, 10:18 AM
QUOTE(markd@mac.com @ Nov 20 2003, 08:09 AM) There are only three bolts that hold the console in place. Two up under the dash and one back behind the shifter in the U-shaped metal piece. Once those are out, you just push, pull and twist it out. It's one of those situations where there is a magic spot where it comes out without force, but you'll never find the magic spot, except by accident. (IMG:style_emoticons/default/biggrin.gif) There's one more under (in front of) the gauge plate in the funky shaped metal bracket. Goes down into the tunnel like the rear screw. |
GaroldShaffer |
Nov 20 2003, 12:26 PM
Victory (IMG:style_emoticons/default/smilie_pokal.gif)
Thanks guys. The bracket under the dash was in the way |
maf914 |
Nov 20 2003, 12:48 PM
Man, it looks like you got a little frustrated during the removal process! (IMG:style_emoticons/default/smash.gif)
I always try to take a deep breath or walk away for awhile before I go into the detsruction mode! (IMG:style_emoticons/default/laugh.gif) Hope the console came out better than the rest of the interior! (IMG:style_emoticons/default/laugh.gif) Mike |
JWest |
Nov 20 2003, 01:16 PM
Wow, I never had to remove the floor to get a console out before! (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/wink.gif)
GaroldShaffer |
Nope, not fustrated at all. I basically just lifted the the
seats off the ground, no floor in the car. Just trying to save what parts i can from this car before it goes to the big scrap yard in the sky (IMG:style_emoticons/default/sad.gif) This car was in destruction mode when I got it. - Garold |
GaroldShaffer |
Nov 20 2003, 01:17 PM
The floor
Drums66 |
Nov 20 2003, 04:49 PM
"WOW" I never thought to use Dynamite to remove a center console! (IMG:style_emoticons/default/laugh.gif)
Lo-Fi Version | Time is now: 2nd January 2025 - 02:17 PM |
