brer |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None ![]() |
I have seen the twin spark dizzies. Straight forward.
Then there are the crank fire twin pack setups. ok. what else can be used? Piggyback systems? (picture is for entertainment purposes only. this is not my motor) Attached image(s) ![]() |
toon1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 ![]() |
EDIS-4 90-93 4cyl models, this info came from the Megasquirt website, MS11 ignition .
Tells all about setting up the VR sensor and trigger wheel. |
DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
EDIS-4, 1990 to 1993 1.9L 4 cylinder engines. Ford Escort, and i think Mercury Lynx.
Grab the trigger wheel, the VR sensor, the module, the coil and as much of the wiring harness as possible. In patricular, the wiring from the sensor to the module and from the module to ECU are shielded. Also the connectors are important. Dave |
toon1 |
EDIS-4, 1990 to 1993 1.9L 4 cylinder engines. Ford Escort, and i think Mercury Lynx. Grab the trigger wheel, the VR sensor, the module, the coil and as much of the wiring harness as possible. In patricular, the wiring from the sensor to the module and from the module to ECU are shielded. Also the connectors are important. Dave Dave, are you using this on your car? |
DNHunt |
EDIS-4, 1990 to 1993 1.9L 4 cylinder engines. Ford Escort, and i think Mercury Lynx. Grab the trigger wheel, the VR sensor, the module, the coil and as much of the wiring harness as possible. In patricular, the wiring from the sensor to the module and from the module to ECU are shielded. Also the connectors are important. Dave Dave, are you using this on your car? Yep, Here's the EDIS wheel adapted to the type IV fan hub. Attached image(s) ![]() |
DNHunt |
Here's the VR sensor on the back of the cooling shroud. it sits under the oil cooler
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
brer mentioned machining the fan to have tooths on it.... that is genius
toon1 |
Nice!!! I'm going to that when I install my MS.
Sorry about the hijack |
brer |
toon1 |
How are you going to do it? A Milling machine?
I would like to see it when you are done. |
brer |
My friend has a shop with CNC.
its a snip to notch an object like the tooth wheel. |
Aaron Cox |
what about orientation?
doesnt it matter where the missing tooth goes? ie... it dictates where you need to put your sensor? and the fan only goes on one way right? i have an extra fan i think i could donate to the cause |
brer |
sensor position would need to be decided first, based on mounting surfaces.
Then you would want it to have a bit of adjustment for fine tuning i'm guessing. is the big notch TDC? or? set crank to desired position, mark the fan where you want the big notch to fall with respect to the sensor. I had though it would be cool to mount the sensor in the timing access hole. incorporated into a screw in device to replace the plug. I have a fan with two busted blades I could play with. |
brer |
anyone have an ignition map for twin spark??
or would one map be used for both sets of plugs? |
Aaron Cox |
sensor position would need to be decided first, based on mounting surfaces. Then you would want it to have a bit of adjustment for fine tuning i'm guessing. is the big notch TDC? or? set crank to desired position, mark the fan where you want the big notch to fall with respect to the sensor. I had though it would be cool to mount the sensor in the timing access hole. incorporated into a screw in device to replace the plug. I have a fan with two busted blades I could play with. oh that is just brilliant! how would you verify timing then? |
brer |
Aaron Cox |
the toothed fan doesnt mean twin blug... you can utilize that for ANY crank fire system.....
big red line/notch on fan is TDC iirc.... |
brer |
doesn't the gap have to be at a certain position?
is it reading TDC or just revolutions? |
Aaron Cox |
i would expect you could index the gap to a certain "position" on the crank....
but i have no experience with edis/crankfire/sds/megasquirt |
Aaron Cox |
brer |
oh that is just brilliant! how would you verify timing then? not sure, but i'd throw one of these in there somehow. (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 29th June 2024 - 03:18 AM |
