> My First 914 FIRE, Now I'm looking for a new wiring harness
tracks914
post Feb 1 2007, 09:46 PM
Canadian Member
Car is on the rotiserrie. The only thing I left on the car was the wiring harness and the fuse panel. The rear wires were all bundled up nicely in a bag in the engine compartment. (IMG:style_emoticons/default/devil.gif)
I was welding up a patch in the fire wall from the drivers compartment side, and I guess some sparks flew into the engine compartment and started the bag on fire. (IMG:style_emoticons/default/new_shocked.gif)
By the time I noticed it was on fire and put it out I had some big clumps of plastic and the fused together wire was toast!!
Anyone got a good used wiring harness....cheap???
r_towle
post Feb 1 2007, 09:57 PM
Custom Member
possibly from an Ljet, 74
Rich
McMark
post Feb 1 2007, 10:05 PM
914 Freak!
I think he needs a whole car harness, Mike. (IMG:style_emoticons/default/wink.gif)
davep
post Feb 2 2007, 08:41 AM
914 Historian
I may have one. Did have lots at one time. PM me if you want to work out something.
markb
post Feb 2 2007, 08:44 AM
914less :(
You could also check with hwgunner. He's stripping a 76.
dr914@autoatlanta.com
post Feb 2 2007, 09:30 AM
QUOTE(tracks914 @ Feb 1 2007, 07:46 PM) *
If you have a 73 you need a 73 harness. They are unique. If you have a 70-71 the harnesses interchange. If you have a 74 you need a 74 it is unique. If you have a 75-76 they interchange.
Jeffs9146
post Feb 2 2007, 11:34 AM
Ski Bum
............(IMG:style_emoticons/default/blowup.gif)
(IMG:style_emoticons/default/shocked[1].gif)
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
JK
Jeff
post Feb 2 2007, 02:07 PM
Resident German
QUOTE(dr914@autoatlanta.com @ Feb 2 2007, 07:30 AM) *
(IMG:style_emoticons/default/agree.gif) i put a '74 harness in my '70 car and it was a lot of work to get it all right.
even needed some grinding and welding ...
save yourself a lot of headache and get a complete harness from the same year.
(IMG:style_emoticons/default/smile.gif) Andy
tracks914
post Feb 2 2007, 04:06 PM
Canadian Member
I'm not too worried about the engine wiring because I want to go with a 6 or a Raby 4 with carbs. Even if I got one from under the dash to the rear as long as I get all the power, lighting, charging, reverse I think I can make it work from there.
Is there a difference between the 73 1.7 and 2.0 harness?Early 73 and late 73?
GWN7
post Feb 3 2007, 01:37 PM
King of Road Trips
I've got one out of a 72...not knowing any better at the time I pulled it out by cutting it in 1/2 in the middle of the tunnel.
The tail section should be the same on all years?
You can have it, if it works to splice into your existing harness if you can't find a compleat one.
It's in my shed so I hope your not in a rush as the shed is burried under snow right now.
tracks914
post Feb 3 2007, 01:52 PM
Canadian Member
I'll PM you.
Since all I think I need is for everything but the FI it just might work.
Snow? You have snow? We have about 12" in my yard right now. We can still drive anywhere by 4x4 and don't need a snowmachine yet!!!
orange914
post Feb 9 2007, 06:26 PM
http://5starmediaworks.com/index.html
ive got a complete 71 still in the car im parting. let me know if your still l@@king
tracks914
post Nov 18 2007, 04:03 PM
Canadian Member
If I put a complete 71 in my car will the 1.7 FI still work?
So far the only differences I see (going to the rear) are:
console gauges wiring is not there
RR Def in not there
seat belt warning lights are not there.
From the fuse panel forward shouldn't they all be the same?
If change the whole thing out, what troubles am I looking forward to??
post Nov 18 2007, 04:11 PM
Resident German
QUOTE(tracks914 @ Nov 18 2007, 02:03 PM) *
'71 in a '73 car won't work unless you do some major modifications, like a '71 steering column etc.
your best bet is to get a complete harness for your year. call EASY and ask john or call HPH and ask rich ...
(IMG:style_emoticons/default/bye1.gif) Andy
EASY
HPH
tracks914
post Nov 18 2007, 08:01 PM
Canadian Member
QUOTE(SirAndy @ Nov 18 2007, 02:11 PM) *
So can I splice the rear section into the '73 harness?
ClayPerrine
post Nov 18 2007, 09:13 PM
QUOTE(tracks914 @ Nov 18 2007, 08:01 PM) *
Whatever you do.... DO NOT SPLICE THE HARNESS TOGETHER
You will end up with problems that will take you months to sort out. I would follow the advice of most of the members here.. get a complete harness from a car of the same year. You will have much better luck by doing that.
Andy wrote an excellent article on how to replace the harness. Pull it now and finish the welding. Then put the replacement complete harness in the car.
tracks914
post Nov 18 2007, 09:25 PM
Canadian Member
QUOTE(ClayPerrine @ Nov 18 2007, 07:13 PM) *
Car is welded, painted and re-assembly is in progress. I was just hoping the colour coding on the harnesses was the same from year to year. Splicing and soldering wires is easy as long as blue goes to blue and green to green!!!! (IMG:style_emoticons/default/w00t.gif)
post Nov 19 2007, 11:31 AM
Resident German
QUOTE(tracks914 @ Nov 18 2007, 07:25 PM) *
wires are different over the years. even in the rear ....
please don't splice ... i got a complete harness in near perfect shape from EASY for $100. they even took it out of the donor car for me, didn't have to get my hands dirty ...
look for the classic thread on how to remove & install a main harness ...
(IMG:style_emoticons/default/shades.gif) Andy
orange914
post Nov 19 2007, 05:10 PM
QUOTE(orange914 @ Feb 9 2007, 04:26 PM) *
i think i still have that 71 uncut body harness $100 shipped
tracks914
post Nov 19 2007, 05:51 PM
Canadian Member
QUOTE(orange914 @ Nov 19 2007, 03:10 PM) *
Thanks but I have a great '71 but I need a good '73.
BTW Andy What if I was switching to carbs?? I was thinking of going with a 2256? Raby engine in this car and don't know if I really need all those wires??????
- Lo-Fi Version Time is now: 24th November 2024 - 08:07 PM
