> Wiring question on a 1.8 l-Jet, FI part of dual relay....
jim_hoyland
post Feb 3 2007, 09:38 PM
Get that VIN ?
One branch of the L-Jet ignition harness goes to the left side of a dual relay. What is the funciton of:
Yellow
Red/Black
Black
r_towle
post Feb 3 2007, 09:51 PM
Custom Member
if you show me a pic, I will go out in the freezing cold barn and tell you what it does...
Rich
ClayPerrine
post Feb 3 2007, 10:58 PM
QUOTE(jim_hoyland @ Feb 3 2007, 09:38 PM) *
Yellow
Red/Black
Black
Yellow - Goes to the 4 pin connection on the left rear of the relay board. Used to close the fuel pump portion of the relay when the starter is engaged.
Red/Black - comes from the double relay, goes to pin 12 on the 12 pin engine harness connector. This is the same pin where the white wire for the aux air regulator on the D-jet connects. It sends the power back to the fuel pump circuit from the double relay.
There are 2 black wires. One goes to the positive side of the coil (probably the one you are thinking of) and the other goes to the negative side of the coil.
Hope that helps.
jim_hoyland
post Feb 4 2007, 09:05 AM
Get that VIN ?
Thanks Clay.
I know where that yellow wire jumps.
I'm in the process of rebuiling a harness from a donar.
Jim
QUOTE(ClayPerrine @ Feb 3 2007, 08:58 PM) *
Yellow
Red/Black
Black
Hope that helps.
ClayPerrine
post Feb 4 2007, 01:18 PM
We are reinstalling the L-Jet FI back onto Doug's car on Sat. I will get someone to take some detailed shots of the harness for you.
QUOTE(jim_hoyland @ Feb 4 2007, 09:05 AM) *
Thanks Clay.
Jim
Yellow
Red/Black
Black
Hope that helps.
jim_hoyland
post Feb 4 2007, 01:31 PM
Get that VIN ?
Thanks. Shoot one showing the bottom of the dual relay too.
QUOTE(ClayPerrine @ Feb 4 2007, 11:18 AM) *
Thanks Clay.
Jim
Yellow
Red/Black
Black
Hope that helps.
jim_hoyland
post Feb 7 2007, 08:35 PM
Get that VIN ?
Been looking at my dual relay wiring; couple of questions:
1. Is the yellow hot only during starting and sending power to the red/black ?
2. Is the red/black hot during normal operation ?
ClayPerrine
post Feb 7 2007, 08:58 PM
QUOTE(jim_hoyland @ Feb 7 2007, 08:35 PM) *
Yellow is only hot when the starter is engaged.
Red/Black is hot any time the key is on.
- Lo-Fi Version Time is now: 2nd January 2025 - 10:40 AM
