bperry |
Lurker ![]() ![]() Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 ![]() |
Doug,
I'm in Addison. Just around the corner from you. I can drop buy and give you hand. PM me. My guess is that one of your ignition wires is bad. I had a similar problem years ago, after changing out plugs. I seem to recall that some ignition "wires" are not wires at all. They use some kind of paste internally. In my case, the plug connector wasn't making proper contact with the internal paste. I pulled my hair out trying to figure out what the problem was before I replaced the wires. Only thing I can figure is that I accidentally pulled on the wire instead of the connector when removing the plug wire. In another case, it caused a heavy misfire between about 2000 and 2200 RPMs. In that case, it turned out that the engine vibration was causing the internal paste to crack or separate and not fire one of the plugs. Talk about odd.... and painful (and expensive) to figure out since it showed up suddenly after no maintenance and only caused a problem in that RPM range. After that second experience, I now refuse to use ignition wires that are not made from real wire. PS, I've got a set of wires, I could bring over that we could try on your engine to see if that is the problem. ---- bill |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
QUOTE I haven't had very good luck with platinum plugs... just regular old Bosch coppers for me. or NGK (IMG:style_emoticons/default/agree.gif) Plugs & Wires sounds like you are almost there! Good luck! Jeff |
dagdal1967 |
What are YOU looking at... ![]() ![]() Group: Members Posts: 372 Joined: 13-March 03 From: Carrollton, Texas Member No.: 423 ![]() |
... In the future, and to all rookie mechanics, do one plug at a time, remove boot, remove spark plug, replace spark plug, and put boot/connector back on. This makes it much harder to screw it up. Another tip would be to label the plug wires so they don't inadvertently get plugged onto the wrong spark plug. This made me laugh because I was very concerned about getting the plug wires back on the wrong plugs. Turns out that the not only did I do them one at a time to make sure I got them back on right, but I found out that the PO had numbered the wires for the same reason. I want to thank everyone again for helping me get through the crisis of faith. I've got lots of things to look at, and I'll be spending some quality time with "Das Weibchen" this afternoon to try out some of your suggestions. I'll let you know how it goes. Doug |
dagdal1967 |
Doug, I'm in Addison. Just around the corner from you. I can drop buy and give you hand. PM me. My guess is that one of your ignition wires is bad. I had a similar problem years ago, after changing out plugs. I seem to recall that some ignition "wires" are not wires at all. They use some kind of paste internally. In my case, the plug connector wasn't making proper contact with the internal paste. I pulled my hair out trying to figure out what the problem was before I replaced the wires. Only thing I can figure is that I accidentally pulled on the wire instead of the connector when removing the plug wire. In another case, it caused a heavy misfire between about 2000 and 2200 RPMs. In that case, it turned out that the engine vibration was causing the internal paste to crack or separate and not fire one of the plugs. Talk about odd.... and painful (and expensive) to figure out since it showed up suddenly after no maintenance and only caused a problem in that RPM range. After that second experience, I now refuse to use ignition wires that are not made from real wire. PS, I've got a set of wires, I could bring over that we could try on your engine to see if that is the problem. ---- bill Bill, Thanks for the offer. I'm going to do some trouble shooting today and see where it gets me, and I'll let you know. If you have some free time this weekend (and I don't get anywhere) I might PM you to see if you can help. This group rocks! (IMG:style_emoticons/default/aktion035.gif) |
dagdal1967 |
Good News ( (IMG:style_emoticons/default/boldblue.gif) ) and bad news ( (IMG:style_emoticons/default/sad2.gif) )
Good News After going through everything I did again, I managed to get the car running smoothly. While I'm not exactly sure what it was that I changed, removing the plug wires from the plugs and checking all the FI & Vacuum connections managed to do the trick. Bad news (Clay ... are you listening?) While I was on a roll, I decided to take your advice and take the access panel under the gas tank off and try to see if the fuel pump was vibrating against something to make all the racket. I really don't think it is. By using the fuel line, I was able to move the fuel pump around quite a bit and no matter which way I moved it (up, down, left, right) it never stopped humming. A also felt what I can only describe as heavy vibration through all of the fuel lines attached to the pump. My only diagnosis is that the re-built fuel pump is buggered. Give me a call when you're back in town and we'll discuss how to handle this, since you purchased it from Zimms. Anyway.. Crisis of faith over. Turns out I was just having a horrible week. Thanks for all the kind words and advice guys. It's great to belong to such a nice group of people. Doug |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
I am kinda jumping in and out here, because I am working a bunch while in California.
If the fuel pump is bad, then I know Zim's will warranty it. But we need to make sure. I should be able to find some time to listen to it for you next week. Keep the faith! |
Lo-Fi Version | Time is now: 26th June 2024 - 05:47 AM |
