ANOTHER wiring question....., Sorry about that. |
Grelber |
Mar 5 2007, 12:50 PM
Insert favorite Don Rickles joke here. Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region |
I've got a brown wire coming out of the main harness, right near the distributor. It has a female spade connector and is not hooked to anything (everything works). I have a 2.0L w/ Webers, so could it be for the original FI??
dr914@autoatlanta.com |
Mar 5 2007, 12:56 PM
914 Guru Group: Members Posts: 8,055 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I've got a brown wire coming out of the main harness, right near the distributor. It has a female spade connector and is not hooked to anything (everything works). I have a 2.0L w/ Webers, so could it be for the original FI?? at the distributor 2.0 black with red positive coil beige aux air valve black with purple tach lead from 1 on coil negitive connection, green with red oil press switch |
Lo-Fi Version | Time is now: 26th September 2024 - 05:30 PM |
