6 Conversions in So Cal, Looking for a Wrench |
kconway |
Mar 14 2007, 09:55 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I was wondering if anybody is doing what Joe does in NM here in SoCal? I'm not a strong wrench, so I'm wondering if anybody is up to the task of droping in a 2.4 liter T motor w/CIS in my car. I'd need the whole conversion done. I'm guessing I could go without a cooler but correct me if I'm wrong. Its a weekend driver, prolly no AXing.
Maybe you know of a shop that likes to do this stuff? Lemme know. Oh, forgot to add...yeah I'm cheap so I'm looking for someone reasonably priced. Kev |
smontanaro |
Mar 14 2007, 10:03 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
If you annouce that you'll have beer and pizza on a specific Saturday doesn't the SoCal 914 crowd magically turn up on your doorstep, wrenches and jackstands in hand? (IMG:style_emoticons/default/biggrin.gif)
Skip |
kconway |
Mar 14 2007, 10:05 PM
Yeah, their giving folks out here...but one can only ask so much. A conversion is prolly a little more than one can ask for steaks and brew. (IMG:style_emoticons/default/biggrin.gif)
Crazyhippy |
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
Use Series 9... it's not that far away, and if you do it now, you may be able to pick it up @ the atomic Ramble....
kconway |
Mar 14 2007, 10:11 PM
Maybe I should back up...
Is a 73ish 911T motor w/cis a decent candidate for a conversion? Will it fit without cutting metal? If I wanted to carb it, can I do it without changing out the cams? Is there some reason why I would want to run carbs vs the injection? |
jd74914 |
Mar 14 2007, 11:00 PM
Its alive Group: Members Posts: 4,818 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
The CIS will be a tight fit (IIRC) but it will fit. The latch for the engine lid might need to be moved. That is a good engine for conversion. You don't need to change the cams with carbs. If you were to change to a wilder cam you would want carbs of MFI.
Aaron Cox |
Mar 15 2007, 10:55 AM
need a CIS fuel pump etc....
the intake boot needs to be shaved and the engine latch would need to be relocated..... carbs can take advantage of wilder cams. |
Lo-Fi Version | Time is now: 2nd January 2025 - 12:03 PM |
