Oil Temp Gauge, Where to put the sending unit?????? |
JBart |
Mar 15 2007, 07:02 PM
UNDER CONSTRUTION Group: Members Posts: 110 Joined: 9-October 06 From: Wildomar Ca. Member No.: 7,019 |
I just bought a VDO oil temp gauge , sending unit and a adapter to put it in with
the oil pres. sending unit. Two functions in one spot the only bad part is the two won't fit due to the engine tin having too small of a hole . So my big ? is is there another spot on the engine to install the temp. sender or do I have to cut some of the tin? And coming from a water cooled background what temp. should a 72' 1.7 w/carbs run ????? Thanks, jbart Attached image(s) |
Aaron Cox |
Mar 15 2007, 07:07 PM
oil temp belongs on the taco plate.....
if you put it up there you will get a false reading (says aircooled.net) |
JBart |
Mar 15 2007, 09:31 PM
oil temp belongs on the taco plate..... if you put it up there you will get a false reading (says aircooled.net) TACO PLATE that sounds like somewhere I like to EAT (IMG:style_emoticons/default/chowtime.gif) I'm sorry that was just wrong not really OK I don't now where the taco plate is coult you point me in the right area ???? by the way arron sorry for not getting back to you about the rain tray. I'm picking up a parts car sat site unseen for 4$$ FI motor and told it has a good trans so i'll have parts for everybody I hope!!!!!!! But if it doesn't have a rain tray i'll be call'n Thanks, jbart |
So.Cal.914 |
Mar 15 2007, 09:40 PM
Small round plate at the corner of the case at the bottom of the engine. Dosen't
take much to strip those bolts that hold it in place, careful when reinstalling. |
SLITS |
Mar 15 2007, 09:43 PM
Your '72 will not have one unless a PO put one there. Yours will be a solid plate.
JBart |
Mar 15 2007, 09:57 PM
Your right I have a solid plate with two bolts holding it in place. Should there be a place to thread the sender in or do you remove the plate and there will be a place to thread the sender in under that.
Thanks , jbart |
Aaron Cox |
Mar 15 2007, 10:04 PM
you need one that has a nut welded onto it, and has a different shape to run an oil temp sender.....
JBart |
Mar 15 2007, 10:08 PM
Any idea on where to get one ???????
JBart |
Mar 15 2007, 10:11 PM
Hey Aaron ,
Is it this weekend your looking for help on your car ? I'll be driving by with a new parts car this sat. I'd love to meet some people jbart |
SLITS |
Mar 15 2007, 10:29 PM
JBart |
Mar 15 2007, 10:34 PM
Thats SLITS
I'll try right now !!!! jbart |
JBart |
Mar 15 2007, 10:35 PM
OOPS
Thanks EVERYBODY jbart |
SLITS |
Mar 15 2007, 10:41 PM
Check your PM
Aaron Cox |
Mar 16 2007, 12:13 AM
sure is... drop on bye.
AA |
Lo-Fi Version | Time is now: 17th January 2025 - 05:43 PM |
