bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
I will post pics, and drain the gear oil too (automatically doen when i take the shift console out)
if anybody has a spare tranny, let me know. I am not doing this anymore. I figure if everything is newly rebuilt, nothing will break for a while--then I'll actually be ABLE to gett to school and work and back. |
bd1308 |
Heh.
I am good! pulled shaft out of transmission, no key piece attached I have it sitting on my desk |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
wow.... never actually thought the roll pin would come out....
order one from mcmaster.com |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
I just welded mine solid. It is amazing how much slop was eliminated.
I do not advise this however. It's just what I did. |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Britt,
If all that happened is the roll pin came out, you can go two directions with this. One, get a new roll pin, remove the rest of the console, fish out the shifter rod actuator, and re-assemble. Or, get a setup all ready to go from someone, Now, the part to remember, the actuator and roll pin go on the rod after you insert the rod through the console (that is why its not welded) So, you need all of this on a bench. The console has an o-ring that you either need to replace, or get some aluminum sealant while you are out and apply a liberal dose to the console to make sure it does not leak. Rich |
bd1308 |
well, the roll pin is in
and it was like six hours ago, but.....the shift actuator was installed upside down! Ended up getting a diamond cut carbide bit to drill out the hardened roll pin and had to put new one in. Oh and it started snowing half-way thorugh |
bd1308 |
now for the reinstall tomorrow....
Lo-Fi Version | Time is now: 26th June 2024 - 01:14 AM |
