Shift Rod Set Screws |
sww914 |
Apr 6 2007, 02:31 PM
I just smash the hell out of the whole assembly with a small hammer to peen it in. It'll never come out that way!
Brando |
Apr 6 2007, 07:45 PM
that is why I bough spares. They are so cheap, why not get 4 instead of two when yo uorder them, toss the ones you remove from the car and have brand new ones to use, just in case. DOn't forget the blue loctite Loctite? Try anti-sieze... How many screws have you had to drill out because that cone screw's head has stripped out because the screw rusted in place? Drilling then having to repair the rod or the coupler. (IMG:style_emoticons/default/chair.gif) |
bd1308 |
Apr 6 2007, 08:17 PM
My screw is stripped out....
im goign to try a oversized allen wrench (5mm) then go to the easy outs. |
911quest |
Apr 6 2007, 09:05 PM
Member Group: Members Posts: 277 Joined: 26-March 06 From: Louisville Ky Member No.: 5,773 Region Association: South East States |
Cap'n Krusty |
Apr 6 2007, 09:17 PM
Tobra |
Apr 7 2007, 08:05 AM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
The set screws have a hole in the side (where the threads are) where they press in a plastic dowel, it acts sort of like nylock. Only so many R&I before you need to replace them. They will still back out without blue loctite, ask me how I know (IMG:style_emoticons/default/wink.gif) They won't be as prone to rust if you put the boot back on to the firewall. When I did my shifter bushings, had no trouble getting cone screws out, and they clearly had loctite on them |
Lo-Fi Version | Time is now: 29th June 2024 - 05:29 AM |
