Heater for Water cooled 914s, As promised, here are the pics |
3d914 |
Nov 6 2011, 07:19 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
I was planning to put one of these
into one of these and hook up the stock fan. It would still use the heater tubes in the longs like a stock system. By locating it in the engine bay, routing should be less of a hassle. |
speed metal army |
Nov 6 2011, 10:56 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Couldnt a guy make some Heat exchangers for the V8 exhaust? (IMG:style_emoticons/default/confused24.gif) Maybe with marine exhaust manifolds, but it's water heat. If you had good sheetmetal skills, a hot air exchanger could be made. Yes!Hot air xchngr is what im talking about.Not that hard.Has anyone done this? |
ruby914 |
Nov 20 2011, 02:00 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
3d914 |
Nov 29 2011, 09:37 PM
ruby,
Its from this catalog. You want page 191. I believe they are in the UK. They also show this . . . |
ThinAir |
Nov 29 2011, 11:49 PM
Best friends Group: Members Posts: 2,555 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
They've got some great stuff! Is there any reason why this couldn't be set up as an external oil cooler? I'm thinking that if you run one on each side and connect them up to the tube in the longs you could have heat like crazy regardless of whether you are aircooled or watercooled. |
3d914 |
Dec 3 2011, 06:34 PM
Ernie, that's basically what I had in mind, except I was going to start with one and go from there.
partwerks |
Dec 3 2011, 06:56 PM
Senior Member Group: Members Posts: 1,599 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
The Renegade Hybrids under dash unit has the capability to run the air hoses up to the defrost vents or vent it out directly from the unit into the cab.
BRAVE_HELIOS |
Nov 7 2014, 11:28 PM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
I have a 71 Chalon with a SBC. When building the car, I incorporated a heater core in the fresh air blower case and ran a couple of feet of heater hose from it with the intention of someday getting it all connected. Well, that day is here. My question is whether it's feasible to tie the the heater core lines to the radiator inlet and outlet hoses via T's instead of running the heater core lines back to the engine's intake manifold and water pump.
What do you think... doable? |
BRAVE_HELIOS |
Nov 8 2014, 03:37 PM
I have a 71 Chalon with a SBC. When building the car, I incorporated a heater core in the fresh air blower case and ran a couple of feet of heater hose from it with the intention of someday getting it all connected. Well, that day is here. My question is whether it's feasible to tie the the heater core lines to the radiator inlet and outlet hoses via T's instead of running the heater core lines back to the engine's intake manifold and water pump. What do you think... doable? Surely someone has an answer; an opinion... something! (IMG:style_emoticons/default/biggrin.gif) |
Mike Bellis |
Nov 8 2014, 04:45 PM
Resident Electrician Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Sorry, I didn't see the question. Yes, in theory you should be able to flow a heater core from the inlet and outlet of the radiator. Flow will vary based on things like hose size, port resistance, parasitic drag, pressure differential, etc... But it should work. If you can find a Y fitting and point it the right direction (with flow) it should work better.
Like this... (IMG:http://www.914world.com/bbs2/uploads_offsite/www.usrallyteam.com-10496-1415486712.1.jpg) |
BRAVE_HELIOS |
Nov 10 2014, 10:27 PM
Sorry, I didn't see the question. Yes, in theory you should be able to flow a heater core from the inlet and outlet of the radiator. Flow will vary based on things like hose size, port resistance, parasitic drag, pressure differential, etc... But it should work. If you can find a Y fitting and point it the right direction (with flow) it should work better. Like this... (IMG:http://www.914world.com/bbs2/uploads_offsite/www.usrallyteam.com-10496-1415486712.1.jpg) Thanks. I think I'll give it a try and see how it goes. What's the worst that can happen... no heat? Already there! |
BRAVE_HELIOS |
Nov 17 2014, 11:30 PM
Sorry, I didn't see the question. Yes, in theory you should be able to flow a heater core from the inlet and outlet of the radiator. Flow will vary based on things like hose size, port resistance, parasitic drag, pressure differential, etc... But it should work. If you can find a Y fitting and point it the right direction (with flow) it should work better. Like this... (IMG:http://www.914world.com/bbs2/uploads_offsite/www.usrallyteam.com-10496-1415486712.1.jpg) This might be a silly question but if I design the system so the heater core coolant T's off the radiator inlet and radiator outlet hoses; how does the coolant know to enter the heater core from the radiator inlet T and exit into the radiator outlet T. Or do I have that reversed? Or do I "T" in and out of the radiator's inlet hose? This is confusing! |
Mike Bellis |
Nov 17 2014, 11:53 PM
Pressure differential. it will flow. This is where angle, T size and internal resistance come into play.
Lo-Fi Version | Time is now: 11th January 2025 - 09:54 AM |
