What is wrong with this picture?, also known as 30$ engine saver? |
Mike D. |
Apr 10 2007, 12:04 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,446 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I certainly wouldn't waste my money, or that of my customer, on the silly tensioner changeover. The last version of the original chain tensioner is fine, and rebuildable. Why spend a bunch of money on something that can have the same failure problem? This is one of the far too many times when the term "upgrade" is misused on the internet. The Cap'n So what is your opinion of the Carerra Tensionsers? I was thinking about doing it to my 3.0, but for no other reason than "if everyone else is jumping off the bridge..." |
Justinp71 |
Apr 10 2007, 12:12 PM
Senior Member Group: Members Posts: 1,595 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I certainly wouldn't waste my money, or that of my customer, on the silly tensioner changeover. The last version of the original chain tensioner is fine, and rebuildable. Why spend a bunch of money on something that can have the same failure problem? This is one of the far too many times when the term "upgrade" is misused on the internet. The Cap'n So what is your opinion of the Carerra Tensionsers? I was thinking about doing it to my 3.0, but for no other reason than "if everyone else is jumping off the bridge..." Cap'n- are you talking about the 930 tensioner? New they're over $200 each and you can get the Carrera kit for around $489 from ebs racing. Why not spend the extra $50? Also my tensioner appeared to lose some tension after the motor was sitting for about a week, but as soon as I turned the motor over they tensioned right up. Is that a sign of a failing tensioner? |
echocanyons |
Apr 11 2007, 07:59 PM
Advanced Member Group: Benefactors Posts: 2,096 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Well the bolt came out through the engine drain plug with a little bit of coaxing.
Fortunately it was in one piece and didn't look banged up. Now on to replacing the tensioners! |
Lo-Fi Version | Time is now: 28th September 2024 - 11:24 AM |
