Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
QUOTE and put a good ole fashioned UMPH on the thng Uhhhhhhh... you mean "Ass" don't ya? (IMG:style_emoticons/default/confused24.gif) |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Well ya gotta 1st determine if the guy has enough ass to tighten the damn thing.
Good ole fashioned Umph is more like a specific torque spec. Little bit less than Really Effin tight. |
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
I like to put a bit of blue loctite on those threads before I screw it in. Not red, blue.
Somebody's gonna come up with some good reason not to use it here, but the tie rod obviously unscrewed it's self, and if there had been some loctite on there in the first place it wouldn't have happened, spacers or no spacers. I also hit my wrench with a big hammer to do the final tightening on these, just to make sure. It would be pretty hard to ever tear up those threads by over tightening, I just want to be sure it's tight. |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Blue loctite would be a fine idea. But this situation sounds like installer error. Not tightened down enough. Loctite, isn't a bad idea, it just shouldn't be necessary.
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
If there are no spacers (big washers), please check the outer tie-rod ends.
The washers will also space out the tie rod to engage the tie rod end by the same amount. (ie: without the spacer, you have that much less thread engagement with the outer tie-rod end.) You don't want those to unscrew themselves either, and you don't want only 1-2 threads of engagement. Good luck with it. |
JWest |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None ![]() ![]() |
The outer tie rod does not look right - it is completely threaded on. Maybe the person who aligned it used the inner for the adjustment and it was left loose (baaaad).
Attached image(s) ![]() |
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
The outer tie rod does not look right - it is completely threaded on. Maybe the person who aligned it used the inner for the adjustment and it was left loose (baaaad). I have to agree... Seems the same to me. Not all alignment shops are experienced in that sense... |
rwjames |
Member ![]() ![]() Group: Members Posts: 326 Joined: 2-June 06 From: Montgomery, AL Member No.: 6,136 Region Association: South East States ![]() |
The outer tie rod does not look right - it is completely threaded on. Maybe the person who aligned it used the inner for the adjustment and it was left loose (baaaad). I have to agree... Seems the same to me. Not all alignment shops are experienced in that sense... I went home at lunch and took the boot off the passenger side. There is not a spacer on it either. Here are a couple of photo's as best as I could get with the boot pulled back. It looks like the right side is threaded in all the way. I guess I'll use some blue locktite and screw the driver's side back in. I'll probably drive it around the neighborhood a little and check it out before I drive it to a shop to have the alignment checked out. After the alignment, I guess I need to check it again and be sure they don't back it out of the steering rack, rather than making the adjustment at the other end. Thanks again for everyone's help. Attached image(s) ![]() ![]() ![]() |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Can you see threads on the tie rod on the end that didn't become disconnected?
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
find the big washers... like john mentioned, in addition to being a rack stop, they also ensure your outer tie rod end has more than a few threads of engagement on it....
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
So far it looks like all the adjustment was done with the end that fell apart. Probably only a few threads of engagement.
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
you are so lucky. i don't get how there can be 0 threads showing on the outside without the spacers. that should cause the outer end threads to be way exposed to make up for the increased overall distance. it just doesn't add up.
k |
PRS914-6 |
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None ![]() ![]() |
you are so lucky. i don't get how there can be 0 threads showing on the outside without the spacers. that should cause the outer end threads to be way exposed to make up for the increased overall distance. it just doesn't add up. k Assuming that the rack side was screwed in all the way, I see what you are getting at......However, this looks more and more that it was never tightened in the first place and it was used for adjustment. It must have been hanging on by only a thread or two.....Big time lucky!. Someone's looking out for you. |
Eric_Shea |
Get the washers and do it right this time.
Anyone have the spec on the washers? |
JWest |
Lo-Fi Version | Time is now: 26th June 2024 - 06:04 AM |
