nick mironov |
nickm ![]() ![]() Group: Members Posts: 204 Joined: 12-June 05 From: San Francisco, CA Member No.: 4,264 ![]() |
Spray glue on the botton of the seat and on the fabric, let dry, and then stretch it into place, taking out any wrinkles.
Find and cut the holes for the rail attachement screws, and install the rails. Attached image(s) ![]() |
nick mironov |
Glue the "shoulders", stretching them as high as possible.
nick mironov |
Back to the backpad.
Install the new cover over the backpad foam padding. You will lots of spray-on glue here, and you may need to get some weight on it overnight while it cures. Install the metal hooks at the top of the fabric. I ended up adding some zip-ties to help shape the top better. Install the metal wire bead in the bottom pocket. Attached image(s) ![]() ![]() |
nick mironov |
Install the backpad over the seat.
Hook the headrest on over the lip on the top of the seat and then swing the bottom down. It should go on easy - no need to force it. Stretch the backpad down and pierce the fabric over the bottm bead with the three pointy hooks, and then bend the hooks down to secure it. Attached image(s) ![]() ![]() |
nick mironov |
Re-attach the interior screws to hold the headrest in place against the seat.
nick mironov |
Spray adhesive and glue in the backing into the cover flap.
Spray adhesive and glue in the loose pieces/flaps. Punch holes for the cover flap screws. Close the flap and install the screws that hold the flap in place. Attached image(s) ![]() |
nick mironov |
Finally the seat cushions...
These are the easiest of all. Simply remove the staples the bottom, peel off the old fabric, stretch the new fabric over the foam padding, and re-staple everything. Install the cushion in the seat, and you are done with the re-upholstery! Note there there was a complicated string/bead tie-down system in the cushions that I decided not to re-install. There were originally meant to hold the top of the seat cushion down to keep it from bulging/doming in the center. There is no noticable difference without them. Attached image(s) ![]() ![]() |
nick mironov |
And the finished product again...
MrKona |
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None ![]() |
Let me be the first to say... NICE JOB! (IMG:style_emoticons/default/beerchug.gif)
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
Yes indeed, nicely done.
You might go back & fix the typos, but otherwise, good job. |
Jerry |
Member ![]() ![]() Group: Members Posts: 413 Joined: 7-April 05 From: Conroe, Texas Member No.: 3,892 Region Association: None ![]() |
Wow, very nice!!!! I think this should go to the "Classics"...... so therefore, this thread is officially nominated !!!!!!!!!!!!!!!!!!
johannes |
Club Porsche 914 France President ![]() ![]() ![]() ![]() Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France ![]() |
GREAT JOB !... I vote for the classics too.
After reading this thread, no one will be scared to do the job himself. |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,807 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I'll 2nd or 3rd the vote on making this a Classic! Great post Nick!!! Probably took as much time to shoot the photos and write it up as the upholstery work. Awesome job!
Rotary'14 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 ![]() |
Great pics, good information. Insant classic!! Awesome job Nick!! (IMG:style_emoticons/default/beerchug.gif) -Rob |
Joe Owensby |
JoeO ![]() ![]() ![]() Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States ![]() |
Nice job. thanks for sharing with us. Joe
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
love that blue fabric.
bigkensteele |
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,199 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States ![]() ![]() |
I can't get enough of these kinds of threads. Stuff that you think you couldn't possibly do properly laid out simply by another guy who has the guts to try it. THANKS!
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
That looks fantastic Nick!
smj |
"Dude, Steve from Berkeley." ![]() ![]() ![]() Group: Members Posts: 591 Joined: 28-August 05 From: Berkeley, CA Member No.: 4,691 Region Association: Northern California ![]() ![]() |
Great job Nick, thanks for putting this together. Even with the difficulties you mentioned, the pictures are great.
I can't get enough of these kinds of threads. Stuff that you think you couldn't possibly do properly laid out simply by another guy who has the guts to try it. These kinds of procedures are essential because afterwards you know exactly what's involved. You may decide to try it, you may decide to write a check -- but you can make an informed decision one way or the other. |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,299 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
This will be a "Classic" for sure.
Thanks for the excellent thread Nick. |
Lo-Fi Version | Time is now: 3rd April 2025 - 04:00 AM |
