johannes |
Club Porsche 914 France President ![]() ![]() ![]() ![]() Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France ![]() |
This thread should be in the "classic"
Gunn1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None ![]() |
Halfnelson |
Member ![]() ![]() Group: Members Posts: 66 Joined: 31-July 17 From: Cornwall Member No.: 21,303 Region Association: England ![]() |
Just want to add a belated thanks for this thread - followed it for my seats and they turned out great
Cheers, Chris |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,694 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Just want to add a belated thanks for this thread - followed it for my seats and they turned out great Cheers, Chris Post some pic's of your handiwork. (IMG:style_emoticons/default/beerchug.gif) |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,154 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
autos international does fabulous work
partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,611 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
Reassemble the three pieces - two side pieces and one center piece. Reinstall using the reverse of the removal process, and you are done with the packpad. This might be a good time to fix you rear glass if it is loose in its frame - before you re-install the backpad. I'm wondering how that's going to work now, with that box kit welded in, as far as those 4 screws at the bottom? |
dstudeba |
Member ![]() ![]() Group: Members Posts: 118 Joined: 3-December 21 From: San Diego Member No.: 26,128 Region Association: Southern California ![]() ![]() |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,761 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
If you need the tabs we make them. In stainless and steel like OEM
For the seat bases, backpad, and all the tabs on the seat buckets. All pop rivet like OEM and are an easy direct replacement. Available in kits or individually. https://914rubber.com/search/?q=Tabs |
Lo-Fi Version | Time is now: 3rd April 2025 - 03:53 AM |
