It's Alive! Vol III, The teener is running... better |
BahnBrenner914 |
Jun 22 2007, 03:10 AM
The girl is gone and all I have now is a beat-up teener Group: Members Posts: 301 Joined: 22-May 04 From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL Member No.: 2,094 Region Association: None |
Well those following my story, the teener was running really crappy and sluggish after a couple miles down the road. So I replaced the fuel filter (IMG:style_emoticons/default/smash.gif) and unkinked the lines.
So I took it out (IMG:style_emoticons/default/driving.gif) and drove around for quite a while, around the block and then around a bigger loop by my house, and it kept running. It didnt totally crap out like it was before (IMG:style_emoticons/default/w00t.gif) , so that's good. It is still surging a little at 50+% throttle, but its driveable. (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/w00t.gif) I havent checked the plug wires or the coil wire yet, but are there any other causes of surging power? |
914nerd |
Jun 22 2007, 10:29 AM
Who you callin' a "Member"? Group: Members Posts: 416 Joined: 18-July 06 From: Los Alamos, NM Member No.: 6,461 |
Well, is it still FI?
If it is, you could have a FI problem (and I will defer to the experts on that one) The real question is why is that 914 not on jackstands where it belongs? (IMG:style_emoticons/default/biggrin.gif) |
effutuo101 |
Jun 22 2007, 10:38 AM
Advanced Member Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
I had a bad aux air pump that caused my surges. take the TPS apart and clean it.
highways |
Jun 22 2007, 01:19 PM
Senior Member Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 |
I had a bad aux air pump that caused my surges. take the TPS apart and clean it. doesn't the factory manual say 'don't remove the TPS'? Isn't it super sensitive the adjustment on how it is positioned- and therefor hard to re-install correctly without some fancy test equipement? I dunno cause I haven't done it- but I was reading up on it lately and it doesn't look easy. |
BahnBrenner914 |
Jun 22 2007, 01:42 PM
I did take the AAR out (IMG:style_emoticons/default/sawzall-smiley.gif) and then put it back in (IMG:style_emoticons/default/smash.gif) cause I thought it was un-gunked (IMG:style_emoticons/default/barf.gif) , but maybe its an electrical problem (IMG:style_emoticons/default/happy11.gif) (cause it was reading 12 or so volts, but I couldnt get a reading for amps on it, and yes I know to put it in-line for amps (IMG:style_emoticons/default/alfred.gif) ). Does anyone know how many amps should be running through the AAR? maybe my multimeter doesnt have enough range. I'll clamp the AAR hose and take it for a drive (IMG:style_emoticons/default/driving.gif) and see if that does anything.
Things arent so good anymore, find the next topic "Hold the Phone... Vol. IV" |
Lo-Fi Version | Time is now: 2nd January 2025 - 06:49 PM |
