ptravnic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None ![]() ![]() |
The only thing I've found is thick rubber hose...
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Someone posted here a few weeks ago that they were able to find a roll of tubing that looked identical (or almost) to the stock tubing at their local hardware store. I recall that it wasn't something I would have expected--possibly electrical conduit type stuff?
--DD |
Mike D. |
OK, It runs now, and pretty good too! ![]() ![]() ![]() Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None ![]() ![]() |
It actually looks alot like the hose I use in my pond. They have it at Lowes & Home Depot, comes in different sizes. But a roll of that would do 10 914s... maybe you can buy it by the foot?
highways |
Senior Member ![]() ![]() ![]() Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 ![]() |
Yep, I found the irragation house that looks identical to OEM rain tray hose at OSH (Orchard Supply and Hardware). It's not an exact fit though but I found that you can join to the OEM rain funnels to it by using some black joint tubes that are sold also in the irragation section- and the joint can be hidden so in the end it will look original.
The irragation hose is like a black rubber material over a wire ring tube, 1" diameter and sold in 25' sections for like $20... different from the OEM tubes that are straight plastic- but at least it looks exactly the same. The only difference it that it looks slightly glossy. |
ptravnic |
Great info guys - I'll make a trip to HD and/or Lowe's
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Got mine at OSH, a 20+ ft roll is around $25. Traded the unused part of the roll for parts.....
ptravnic |
WOO HOO! Got some from Home Depot today: 20' for $20. The funnel doesn't fit in as snuggly as the original (hose clamps will easily do the trick).
I tried to find the link on their website for others to track but no luck so I took a pic of the tag. I also pulled an old hose to show side by side comparison. ![]() ................................................................................................................................... ![]() |
rmital |
Northeast optimist ![]() ![]() ![]() Group: Members Posts: 1,948 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 ![]() |
20' of new rain tray hose...that might be just enough to do all your 914s.
ptravnic |
20' of new rain tray hose...that might be just enough to do all your 914s. that was what I was thinking... but then there's the hose in the front trunk, behind the gas tank to replace... Lil jobs like this are about the only ones I can do in this heat, it's been low 90's the past couple days (IMG:style_emoticons/default/drooley.gif) |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Thanks for posting the photo and source for the tubing. I also need to replace the rain tray tubes. They were fine until I removed them to degrease and clean them. I had cleaned them with a brush and was rinsing them off with a hose. I figured I'd sort of sling it to get the water out with a little centrifugal force and the sudden flexing caused the tube to break. SOB! Probably a little brittle from years of heat exposure. (IMG:style_emoticons/default/sad.gif)
ptravnic |
sudden flexing caused the tube to break. SOB! Probably a little brittle from years of heat exposure. (IMG:style_emoticons/default/sad.gif) Exactly the reason I had to replace one of my hoses - then figured they could all use modernized. Glad you found it useful. -pt |
Lo-Fi Version | Time is now: 26th June 2024 - 06:47 AM |
