> jus took my 914 v8 for inspection, and passed on hc 514 out of 600
jimkelly
post Jul 20 2007, 02:18 PM
Delaware USA
but failed on co's 6.84 out of 6.00.
nappa dude suggested i retard the dist 1/4 inch.
also suggested maybe removing the air cleaner just for the emissions test.
any comments??
jim
skline
post Jul 20 2007, 03:02 PM
Born to Drive
If you have to do an emissions test, do what ever you have to do to make it pass and then change it back afterwards. How often do you have to do it?
jimkelly
post Jul 20 2007, 04:11 PM
Delaware USA
every two years - not bad - jim
Mikey914
post Jul 20 2007, 04:34 PM
The rubber man
Run the gas down til you get the idiot light. Add 1 Qt denatured alchol run it through then fill the tank after to dilute. It burns with out producing CO, and is used on board boats because of that. However it is not good for certian kinds of plastics, so you will not want it in your tank for very long. (IMG:style_emoticons/default/happy11.gif)
jimkelly
post Jul 20 2007, 04:45 PM
Delaware USA
denatured alcohol - thanks
i have been told this by a local buddy but he warned the same thing about the damage it can do to rubber and plastics.
thanks
jim
Gint
post Jul 20 2007, 06:14 PM
Mike Ginter
I've gotten a few carb'd cars (still have a one of my old Chevy trucks laying around in addition to 914's) through testing that were on the edge of CO by retarding the timing a tad.
jimkelly
post Jul 20 2007, 06:24 PM
Delaware USA
cool - so i was not wrongly advised - will try that - that - jim
QUOTE(Gint @ Jul 20 2007, 04:14 PM) *
Gint
post Jul 20 2007, 06:33 PM
Mike Ginter
QUOTE(jimkelly @ Jul 20 2007, 05:24 PM) *
Just a little, don't go crazy. You're not far off anyway. Changing the timing may very well affect your HC a little bit too. If it costs you to have the thing tested every time it might be worth it to pay a shop this time for 30 minutes labor to put it on an analyzer and adjust it to pass. Or find someone that has an analyzer. Then you can tune for performance after the test and make notes on what timing and mixture settings it took to get it to pass so 2 years down the road you can tweak,test, re-tune and be done.
jimkelly
post Jul 20 2007, 06:41 PM
Delaware USA
nope - no charge to have it retested.
jim
QUOTE(Gint @ Jul 20 2007, 04:33 PM) *
drive-ability
post Jul 20 2007, 10:22 PM
Jim,
If you were to lean out the idle system a bit, team that with a 4 to 6 degree retarding of the timing. Doing that together may keep your HC from spiking. I assume you are doing an idle and cruse test? For the cruse portion I would install a new air-filter, make sure the choke plate is open all the way and you may be good to go. Your not far off, those readings and limits are insanely high compared to new cars. My guess is you take the place of around 300 new cars just with you V8 car, Ha Ha Ha isn't that great! (IMG:style_emoticons/default/aktion035.gif)
scotty b
post Jul 20 2007, 11:30 PM
rust free you say ?
QUOTE(jimkelly @ Jul 20 2007, 12:18 PM) *
any comments??
jim
Move (IMG:style_emoticons/default/chairfall.gif) No emissions testing in Richmond (IMG:style_emoticons/default/poke.gif)
jimkelly
post Jul 21 2007, 06:25 AM
Delaware USA
the test is only at idle.
i am not changing engines but do wonder how well a brand new crate 350 from paceperformance would emissions wise with the right components??
http://paceperformance.com/index.asp?PageA...p;ProdID=154046
jim
QUOTE(drive-ability @ Jul 20 2007, 08:22 PM) *
Jim,
drive-ability
post Jul 22 2007, 01:35 AM
[quote name='jimkelly' date='Jul 21 2007, 05:25 AM' post='926311']
Jim,
I have a new GM crate motor much like that in my V8 car and it really runs great! I have no emission testing here in Ca. but surely it would help to have a fresh set of valves. Your carb and ignition systems would likely still cause the engine to fail, you just need an adjustment or two. (IMG:style_emoticons/default/driving.gif)
JPB
post Jul 22 2007, 09:17 AM
The Crimson Rocket smiles in your general direction.
Crap! Sorry to hear that. Can't you just get Antique tags and bypass the whole emission scam deal? If all else fails, sell the car to me (IMG:style_emoticons/default/biggrin.gif)
scotty
post Jul 22 2007, 12:02 PM
The Fun Never Stops
QUOTE(drive-ability @ Jul 20 2007, 09:22 PM) *
Soooo right! I feel guilty in my car for the first block...after that (IMG:style_emoticons/default/rocking nana.gif)
and I just have a carbed /6!
Brando
post Jul 22 2007, 04:59 PM
BUY MY SPARE KIDNEY!!!
Running any emissions control on the exhaust side?
Also heard of running a quart of acetone to help with bringing down levels... Never tried, we tune our cars to pass if asked and paid to.
jimkelly
post Jul 22 2007, 05:06 PM
Delaware USA
nope - in delaware a car has to be 1968 model year or older - it is not like in VA where a car has to be 25 years old or older : (
i will get it thru though this or next week.
jim
QUOTE(JPB @ Jul 22 2007, 07:17 AM) *
jimkelly
post Jul 22 2007, 05:14 PM
Delaware USA
nope - no emissions at all
denatured alcohol is what I heard - i am gonna run my gas tank near empty and put a little in and then get it tested again at dmv.
pic of my engine today
http://www.pbase.com/jimkelly/image/82652516
jim
QUOTE(Brando @ Jul 22 2007, 02:59 PM) *
messix
post Jul 22 2007, 08:16 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
that air cleaner is to restrictive. not enough media area on the filter.
jimkelly
post Jul 22 2007, 08:31 PM
Delaware USA
too restrictive - i was wondering about that - i'll see if i can find another - jim
QUOTE(messix @ Jul 22 2007, 06:16 PM) *
- Lo-Fi Version Time is now: 2nd January 2025 - 01:56 PM
