Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,167 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
So, after having had the pleasure to drive this beautiful, unmolested, all original, 37k miles 914-6 today, i can't help but wonder if we should attempt to list all the differences between an early /6 and early /4 in terms of originality.
I believe it would be of tremendous help to have a list of things "to look for" when doing a PPI on such a time-capsule. What do ya'all think? (IMG:style_emoticons/default/idea.gif) Andy ![]() |
i'll start ... (IMG:style_emoticons/default/biggrin.gif)
- it should have a flat /6, 2.0L motor (doh!) - firewall center engine mount - no /4 mounts - factory oil-tank - different relay board - "hook" for the oil-line on drivers side rear long - 911 style ignition switch and column for '70/'71 models - *no* hole in the front trunk for the /4 air hose to the spare tire - black "tar" around the front upper shock towers - different windshield washer bottle - electric washer pump - real 5-lug axles - "914-6" badge - handthrottle in front of the shifter - different throttle cable routing, using a tranny mounted pivot - different paint code on the karman badge - different VIN, starting with "914" (doh! again) - no rain-tray under engine lid. - Dash top has no center vent - - what else? (IMG:style_emoticons/default/idea.gif) Andy |
Johny Blackstain |
Walnut Elite Stratocaster player ![]() ![]() ![]() ![]() Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region ![]() ![]() |
i'll start ... (IMG:style_emoticons/default/biggrin.gif) - it should have a flat /6, 2.0L motor (doh!) - firewall center engine mount - no /4 mounts - factory oil-tank - different relay board - "hook" for the oil-line on drivers side rear long - 911 style ignition switch and column for '70/'71 models - *no* hole in the front trunk for the /4 air hose to the spare tire - black "tar" around the front upper shock towers - different windshield washer bottle - electric washer pump - real 5-lug axles - "914-6" badge - handthrottle in front of the shifter - different throttle cable routing, using a tranny mounted pivot - different paint code on the karman badge - different VIN, starting with "914" (doh! again) - "dogbone" pass. side footrest (did early /4s have those too?) - different center console (did early /4s have those too?) what else? (IMG:style_emoticons/default/idea.gif) Andy That crap is stock? I still have it w/ @ least 3 layers of paint on top of it (IMG:style_emoticons/default/sad.gif) . (IMG:style_emoticons/default/stromberg.gif) ! |
orthobiz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,757 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest ![]() ![]() |
No plastic drip pan under engine cover.
Paul |
BS Chairman |
Member ![]() ![]() Group: Members Posts: 98 Joined: 27-December 02 From: Southeast Michigan Member No.: 28 ![]() |
Tool kit
Steel wheels - 6/10solts 4/8solts Dash top no center vent Headliner or not for the 6 or 4 ? Bigger master brake cyl Different center console (did early /4s have those too?) - yes (IMG:style_emoticons/default/confused24.gif) Gary |
Pat Garvey |
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,900 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States ![]() |
The pass side dogbones were an option on early fours.
Andy.....GREAT thread - way past due! Pat ps: what's that strange looking Schwartzeneger kinda 914 in the background of the photo? Hmmm? Pat |
No plastic drip pan under engine cover. good one, i'll add it to the list ... (IMG:style_emoticons/default/thumb3d.gif) |
Tool kit - what are the differences? Steel wheels - 6/10solts 4/8solts - good call, anybody got pictures? Dash top no center vent - added to the list Headliner or not for the 6 or 4 ? - this car had headliner, so had my '70 /4 Bigger master brake cyl - dunno? anybody? Different center console (did early /4s have those too?) - yes - ok, list updated |
Johny Blackstain |
Tool kit - what are the differences? tool kit for the six from previous post. 65-70 911 tool kit w/ 914 towing eye added. Attached image(s) ![]() |
BS Chairman |
Steel wheels Yellow 914/6-1970
![]() Gary |
1970 Neun vierzehn |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 ![]() |
Jasfsmith |
Senior Member ![]() ![]() ![]() Group: Members Posts: 556 Joined: 4-October 04 From: Bangor, ME Member No.: 2,882 Region Association: North East States ![]() ![]() |
i'll start ... (IMG:style_emoticons/default/biggrin.gif) - what else? (IMG:style_emoticons/default/idea.gif) Andy My "plain Jayne" '70 914-4 did not have a center console. Neither the '4 or '6 had a headliner. |
BS Chairman |
i'll start ... (IMG:style_emoticons/default/biggrin.gif) - what else? (IMG:style_emoticons/default/idea.gif) Andy My "plain Jayne" '70 914-4 did not have a center console. Neither the '4 or '6 had a headliner. My six had no headliner also, but I bought it in 1997 so who knows. Now Dr.914 told me at parade it was the way it came from factory! HELP!!! Who's right. Gary |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,153 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
i'll start ... (IMG:style_emoticons/default/biggrin.gif) - what else? (IMG:style_emoticons/default/idea.gif) Andy My "plain Jayne" '70 914-4 did not have a center console. Neither the '4 or '6 had a headliner. My six had no headliner also, but I bought it in 1997 so who knows. Now Dr.914 told me at parade it was the way it came from factory! HELP!!! Who's right. Gary You are right. No headliner in the early sixes from the factory. Do not when it changed but all 71 and 72 sixes had a headliner installed |
Johny Blackstain |
antenna = radio? What kind if I may ask?
BTW: post # 908 (IMG:style_emoticons/default/biggrin.gif) This post has been edited by Johny Blackstain: Jul 23 2007, 06:07 PM Attached image(s) ![]() |
antenna = radio? What kind if I may ask? It appears that most early 914s, /4 or /6, had a radio/antenna installed by the dealer. I can't remember seing an original early car that didn't have a Hirschman antenna, if one was installed. I'd imagine that the P+A dealer would be more likely to put a Blaupunkt or Becker radio in a /6, as opposed to the dealer installed Motorola that came in my /4. Paul |
Johny Blackstain |
It appears that most early 914s, /4 or /6, had a radio/antenna installed by the dealer. I can't remember seing an original early car that didn't have a Hirschman antenna, if one was installed. I'd imagine that the P+A dealer would be more likely to put a Blaupunkt or Becker radio in a /6, as opposed to the dealer installed Motorola that came in my /4. Paul I'm sportin a Frankfurt USA, or @ least I will be after I pull out the Sacramento CD player. I hope it still works... (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/dry.gif) BTW: post # 909 for me (IMG:style_emoticons/default/biggrin.gif) Attached image(s) ![]() |
mikey |
Member ![]() ![]() Group: Members Posts: 424 Joined: 30-January 03 From: San Francisco Member No.: 214 Region Association: None ![]() |
You can't see them, but the 914-6 rear axles and CV joints have one more spline than the 914-4s do. (Not much use knowing this for a PPI though)
Rear brake caliper & handbrake is way different than the 914-4. |
TJB/914 |
Mid-Engn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,398 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest ![]() ![]() |
Hi guys,
I have a serious question. (IMG:style_emoticons/default/popcorn[1].gif) Can a late 1970 914-6 with a 0 after the 914 on the vin # and titled as a 1971 be converted to a factory 1971 M-471 option car???? Example: vin # 91404321?? (late#'s) and titled as 1971 be a real 1971??? Inquiring minds want to know, because I know of a 914-6 that's for sale??? Need answer ASAP. Wolfgang are you interested?? (IMG:style_emoticons/default/unsure.gif) Tom |
Gustl |
914 enthusiast & historian ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,776 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria ![]() ![]() |
Hi guys, I have a serious question. (IMG:style_emoticons/default/popcorn[1].gif) Can a late 1970 914-6 with a 0 after the 914 on the vin # and titled as a 1971 be converted to a factory 1971 M-471 option car???? Example: vin # 91404321?? (late#'s) and titled as 1971 be a real 1971??? Inquiring minds want to know, because I know of a 914-6 that's for sale??? Need answer ASAP. Wolfgang are you interested?? (IMG:style_emoticons/default/unsure.gif) Tom Tom, it might be my lack of knowing english, but unfortunately I didn't get the point of your question - I've no idea what you're asking (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/sad.gif) but the VIN you showed is incomplete there is always a rumor, that the factory might have built M471 cars in MY'70 (914.0.43.xxxx), but only at special request - not as a standard procedure remember - they also built the competition cars from the very beginning of the production BUT - there's no proove yet for sure - if there is a MY'70 914-6 with the M471 option, I would be the 1st who's interested in (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/wavey.gif) Gustl |
Lo-Fi Version | Time is now: 31st March 2025 - 04:44 PM |
