pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,886 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
Not sure if it was mentioned, I did not see it.
The early 914 glove box door pull is smaller on my 70 914-6. |
sixerdon |
Member ![]() ![]() Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 ![]() |
6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
wheel base is wider.... by 4MM
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
6freak |
track. (wheel base is distance from front wheel center to rear wheel center.) ok works for me (IMG:style_emoticons/default/smile.gif) |
sixerdon |
track. (wheel base is distance from front wheel center to rear wheel center.) ok works for me (IMG:style_emoticons/default/smile.gif) There are actually two "track" dimensions for any vehicle......Front & Rear. The factory spec comparing 914/4 vs. 914/6 were as follows; Front Rear 914/4 1341 mm 1377 mm 914/6 1361 mm 1382 mm The differences were due to "stock" wheel width (4-1/2" vs 5-1/2") and the /6 having vented discs up front. The spec changed again when the /4's got 5-1/2" wheels; 1343 mm 1383 mm Keep in mind this information is when they were new with stock equipment. Don |
sixerdon |
A few other notable dimensions:
The overall height of the /6 was higher than the /4. Factory specs were; Height (unladen) /6 = 48.4" /4 = 48.0" (thru '72) Ground Clearance (loaded): /6 = 5.4" /4 = 4.7" (thru '72) The dimensions for the /4 changed beginning in '73. Don |
pete000 |
I did not see it mentioned. Did all the early 914's receive the white head light surrounds. I have seen it mentioned on othe fourms the six cars got black??
I have seen several early photos of six cars with white lamp surrounds. I assumed the black ones came later? |
mikey |
Member ![]() ![]() Group: Members Posts: 424 Joined: 30-January 03 From: San Francisco Member No.: 214 Region Association: None ![]() |
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
Black surrounds came out in mid 1973.
6freak |
I did not see it mentioned. Did all the early 914's receive the white head light surrounds. I have seen it mentioned on othe fourms the six cars got black?? Mine are original and they're tan/beige, not white. Mine are original and they`re white, not tan/beige.... (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/biggrin.gif) |
pete000 |
Its interesting on the internet how some spout off facts, but they are actually quite clueless.
I had an idea all the early 914s including the sixes were white or now aged off white...! |
6freak |
Its interesting on the internet how some spout off facts, but they are actually quite clueless. I had an idea all the early 914s including the sixes were white or now aged off white...! Did you just call me clueless!....If so why??...and that`s not very nice (IMG:style_emoticons/default/confused24.gif) |
ArtechnikA |
QUOTE Did you just call me clueless! Not unless you were one of the ones claiming /6's got back headlight surrounds... QUOTE I have seen it mentioned on othe fourms the six cars got black?? |
6freak |
QUOTE Did you just call me clueless! Not unless you were one of the ones claiming /6's got back headlight surrounds... QUOTE I have seen it mentioned on othe fourms the six cars got black?? My bad (IMG:style_emoticons/default/slap.gif) .. I should have read farther back (IMG:style_emoticons/default/smile.gif) |
Pat Garvey |
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,900 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States ![]() |
OK, with the bickering removed, let's just come to the realization that ALL 914's thru 1973 had white headlight surrouds. Four or Six didn't matter - white.
Undoubtedly, many white surroubds have been altered in hue by age and UV, but they were once bone white. No exceptions known. BTW, the yellowed white surrounds are easily restored. |
6freak |
QUOTE BTW, the yellowed white surrounds are easily restored. How?...would`nt hurt to make mine look new again (IMG:style_emoticons/default/smile.gif) |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,236 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
mike, go mclendon's and buy some "30second Miracle" cleaner. wash both surrounds lightly with detergent and put them both, yes at the same time, in a bucket with a diluted solution. make sure they are COMPLETELY covered. rinse and check every 5 minutes or so and swish them around. really rinse them well when they are white enough for you. the surrounds will look great.
k |
tumamilhem |
LUFTBRIGADE ![]() ![]() ![]() Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States ![]() |
Tool kit - what are the differences? tool kit for the six from previous post. 65-70 911 tool kit w/ 914 towing eye added. I don't have the factory tool kit for my car, but would like to put one together. If yours is complete, can you please tell me everything that came with the tool kit? I have a 1975 914 (that I am selling in the classifieds (http://www.914world.com/bbs2/index.php?showtopic=197510&st=0&gopid=1769486&#entry1769486) and obtaining a 1974. Thank you! (IMG:style_emoticons/default/beerchug.gif) |
DM71SIX |
Newbie ![]() Group: Members Posts: 18 Joined: 30-September 05 From: CUYAHOGA FALLS, OHIO Member No.: 4,893 ![]() |
i'll start ... (IMG:style_emoticons/default/biggrin.gif) - what else? (IMG:style_emoticons/default/idea.gif) Andy My "plain Jayne" '70 914-4 did not have a center console. Neither the '4 or '6 had a headliner. My six had no headliner also, but I bought it in 1997 so who knows. Now Dr.914 told me at parade it was the way it came from factory! HELP!!! Who's right. Gary You are right. No headliner in the early sixes from the factory. Do not when it changed but all 71 and 72 sixes had a headliner installed |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:12 AM |
