Wednesday, 2 April 2025 |
T H O M A S |
Senior Member ![]() ![]() ![]() Group: Members Posts: 626 Joined: 1-August 03 From: Donaueschingen, Germany Member No.: 974 Region Association: None ![]() |
transmission case on the /6 has a 911 #,same case as 911/01 70 and 71 only
Attached image(s) ![]() |
T H O M A S |
the hump is missing on /6 rear calipers ,left is /4 ,right is /6 in this picture
MoveQik |
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,654 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region ![]() ![]() |
Ignition key location?
sixerdon |
Member ![]() ![]() Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 ![]() |
Pat Garvey |
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,900 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States ![]() |
The north american cars have the VIN on a plate in the front windshield. The 914/6 numbers are recessed into the plate while the 914/4 numbers are raised. This is so interesting! Very logical too. Never picked that out before! This thread may be "oh, yeah, I know that" to sixers, but me, a "fourer", it is a very good education! Thanks guys & keep it coming! Pat |
mel reckling |
Member ![]() ![]() Group: Members Posts: 107 Joined: 28-November 07 From: north royalton, ohio Member No.: 8,385 ![]() |
Ignition key location? Yes, indeed. The ignition switch is on the dash to the left of the steering column for '70 & '71 sixes. Unless you own a rare '72 six with the switch back on the column. Don One of them 72s you speak of. Attached image(s) ![]() ![]() |
6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
antenna = radio? What kind if I may ask? It appears that most early 914s, /4 or /6, had a radio/antenna installed by the dealer. I can't remember seing an original early car that didn't have a Hirschman antenna, if one was installed. I'd imagine that the P+A dealer would be more likely to put a Blaupunkt or Becker radio in a /6, as opposed to the dealer installed Motorola that came in my /4. Paul My 1970 914-6 as no radio therefor no antenna no holes for it and the dash weave thingy is one solid piece from the colume too the glove box (no seams).One hole for the lighter and a square hole for the heater controls. I heard that was rare??(IMG:style_emoticons/default/flag.gif) |
6freak |
Lavanaut |
Hungry Mind : Thirsty Gullet ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest ![]() |
Didn't see that anyone had yet mentioned the fact the that Fours have the "hub-centric" rotor, with the integrated hub/rotor assembly. Hopefully I've got that terminology correct...
Quick aside ~ I'm looking for a thread similar to this, but one that compares the differences of the Sixes across the '70-'72 model years. Does one exist? thanks |
70Sixter |
Member ![]() ![]() Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States ![]() |
Try RoadGlue. There is a lot of historical info. And a list of known -6s.
6freak |
Ignition key location? Yes, indeed. The ignition switch is on the dash to the left of the steering column for '70 & '71 sixes. Unless you own a rare '72 six with the switch back on the column. Don One of them 72s you speak of. .how can you tell thats a 72-6 i sure cant (IMG:style_emoticons/default/confused24.gif) |
1970 Neun vierzehn |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 ![]() |
The car that's depicted is Mel's, he owns the '72 /6. Further clues include the higher redline tach and the combo gauge just to the left of the aforementioned rev counter. Paul |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,254 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Didn't see that anyone had yet mentioned the fact the that Fours have the "hub-centric" rotor, with the integrated hub/rotor assembly. The front suspension in the 914/6 is substantially different from the 914/4. The 911T donated the front suspension for the 914/6. The 914/4 used a strut design that was somewhat similar, but the brakes were VW411, the A-arms & torsion bars used a different spline count, and the steering rack was very similar. Ball joints and tierod ends were 911. The 914/4 rotor (VW411) combined the hub and bearings. There were three versions of the rotor: early and mid were not hub-centric, the last one was. Mid and late had a different offset from the early version; this matched the changes to the front strut, ball joint & calipers in very late 1972 MY. Late calipers had two bleed screws and thicker pads. The thicker pads required the rotor to be set out a little farther. The introduction of hub-centric required modifications to many rims as well. |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 124,307 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
Engine lid had smaller diameter (lighter) torsion springs since no drip tray. Rare to get Factory installed radio/antenna on 70's (1 of mine has it). Although it has been said that a Heated/Tinted rear window did not exist. Mine has it.
T.C. |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,299 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
QUOTE Double bleeders on the 4 model!!! Only the later -4's (73-76) had double bleeder. |
Eric_Shea |
QUOTE Didn't see that anyone had yet mentioned the fact the that Fours have the "hub-centric" rotor, with the integrated hub/rotor assembly Only the later -4's (73-76) had "hub-centric" rotor. |
6freak |
QUOTE Didn't see that anyone had yet mentioned the fact the that Fours have the "hub-centric" rotor, with the integrated hub/rotor assembly Only the later -4's (73-76) had "hub-centric" rotor. So i have two ? whats HUB-centric rotor and did all 914have the vinyl sail panels i see so many without the vinyle panel and i was told they all came with the panels covered (IMG:style_emoticons/default/confused24.gif) |
Eric_Shea |
QUOTE whats HUB-centric rotor A rotor with a circular ridge to center the front wheel. Later model 911 rears have this on the hub as well. QUOTE did all 914have the vinyl sail panels No. I'd be willing to bet 90% or more came with the vinyl but LE's and others came without. Vinyl was considered an option but... again, almost all cars came with it (statistically). |
6freak |
QUOTE whats HUB-centric rotor A rotor with a circular ridge to center the front wheel. Later model 911 rears have this on the hub as well. QUOTE did all 914have the vinyl sail panels No. I'd be willing to bet 90% or more came with the vinyl but LE's and others came without. Vinyl was considered an option but... again, almost all cars came with it (statistically). still learning every day thanks |
smontanaro |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest ![]() |
My 1970 914-6 as no radio therefor no antenna no holes for it and the dash weave thingy is one solid piece from the colume too the glove box (no seams).One hole for the lighter and a square hole for the heater controls. I heard that was rare?? I don't know how rare it is, but my /6 also apparently never had a radio. It's as you describe and the speaker boxes are empty. Skip |
Lo-Fi Version | Time is now: 1st April 2025 - 07:11 PM |
