Phoenix-MN |
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 ![]() |
I have finally mated the engine and transmission together and went through the put together - take apart, put together - take apart process about 5 times to get the throwout bearing free play where I wanted it, I started out with 1 washer under the pivot ball that was about .059" thick and this only had about 1/16" free play at the end of the clutch arm. I ground the washer down to .030" and this resulted in almost 1/2" free play (too much). After several variations I ended up with a washer that was .050" thick and gave me a little less than 1/4" free play. As you can surmise, it doesn't take much to make a large change in the free play movement.
Here's a picture of the assembled engine/transmission, I have a small issue to iron out with the drivers side header before it goes into the car. It's getting closer (but no light at the end of the tunnel yet) ![]() |
pjhaun |
Member ![]() ![]() Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None ![]() |
Phoenix-MN |
dbledsoe |
Mutineer ![]() ![]() Group: Members Posts: 300 Joined: 13-May 03 From: Boise, ID. Member No.: 687 ![]() |
Phillip,
That would make sense since as I have found there is but one spot a GM alternator can be mounted (without setting the engine back), and the only commercially available mount to put it there (that I am aware of) is the little known, and expensive, Champion billet machined alternator mount that Paul turned me on to. Even at that the Champion billet alternator mount will only take one type of GM alternator, the GM CS alternator. With that said, the Champion alternator mount is an incredibly beautiful piece of machine work. Don |
Phoenix-MN |
Other side
![]() These are Sanderson BS-1 headers but with a catch. They are both passenger side headers (IMG:style_emoticons/default/biggrin.gif) This gives more clearance for the shift rod between the header and oil pan. |
JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
Hey Phillip, I remember your car from the meet I had at my pizza parlor in Monmouth years ago. That is one sweet ride you have. Good to know you are still around. Hopefully we will see each other at a meet again soon. Sorry to semi hijack the thread- Jamie
pjhaun |
Phoenix-MN |
Phoenix-MN |
pjhaun |
Hey Phillip, I remember your car from the meet I had at my pizza parlor in Monmouth years ago. That is one sweet ride you have. Good to know you are still around. Hopefully we will see each other at a meet again soon. Sorry to semi hijack the thread- Jamie Jamie, We had a great time. It's been a long time since we have been at any 914 get togethers. The car has been down for a couple of years . Hope to have the car running by the end of the year. Phillip |
pjhaun |
pjhaun |
Phoenix-MN |
Phillip,
The ring is hand made from a 6" round by 1" thick aluminum round. I did it all with a drill press and hole saws. I am using 914 CV's and the ring fits them "snugly" and uses 2 set screws to hold it in place. The sensor is a Cherry magnetic reed switch MP200701. This drives a stock 78SC electronic speedometer. |
pjhaun |
Phillip, The ring is hand made from a 6" round by 1" thick aluminum round. I did it all with a drill press and hole saws. I am using 914 CV's and the ring fits them "snugly" and uses 2 set screws to hold it in place. The sensor is a Cherry magnetic reed switch MP200701. This drives a stock 78SC electronic speedometer. So!!!, Paul!!!, Could I commission you to make one for me; to fit 911 CV? How much would it cost even with the magnetic switch? Thank You!!!! Phillip J. Haun Oak Harbor, WA. |
Phoenix-MN |
Phillip,
I would like to be able to say yes but I'm going to have to decline. The ring and sensor seemed to work properly on a bench setup for testing but it has not been proven to work on the "road" yet. I would hate to make and charge someone for a part that ends up not working as intended. It took me many-many hours of hand fab work to make it and I would have to ask way too much money for it. If it does pan out and works properly this part would be a good canidate for a cnc shop to turn out a small run. Once road tested this could be something that could be marketed to the masses (small 911 and 914 masses that is) that want to switch over to an electric speedometer. Paul |
Lo-Fi Version | Time is now: 25th June 2024 - 12:23 AM |
