The official chappy 914-6-gt-turbo carrera thread, The car is real scary to drive, clutch is broke in, im not! |
iamchappy |
Aug 1 2011, 07:43 PM
Man i love driving my car, i have about 400 miles of stop and go driving on the kevlar clutch now, i WOT boost in 2nd through 3rd last night and the clutch held tight this was at 11 lbs of boost so i turned it up to 13 and it still held fine on my next run i am going to turn it up to 14.5 now and see how it goes. I will stay out of boost in 4th and 5th for a few more hundred miles just to be safe on the clutch, but things are looking promising so far.
914coop |
Aug 1 2011, 07:55 PM
Member Group: Members Posts: 214 Joined: 5-September 08 From: Minneapolis Member No.: 9,514 Region Association: Northstar Region |
That's great Chappy.
Pulling for it to hold . Irv |
rick 918-S |
Aug 1 2011, 10:09 PM
Hey nice rack! -Celette Group: Members Posts: 20,826 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Man, at our altitude and air density 14.5 lbs of boost is a ton! Good to here the clutch is holding.
iamchappy |
Aug 2 2011, 07:10 AM
Nothing quite like free water injection, car feels like a rocket sled...
iamchappy |
Aug 12 2011, 08:57 PM
Damn am i enjoying my car, just got back from an evening drive, perfect weather, top off, great tunes, and the car just totally rips, clutch grabbed all the gears i threw it through. If i didnt have a few frosty beverages after i got back home i would jump back in it and take it out for some more fun......
I cant wait till tomorrow....... |
iamchappy |
Aug 16 2011, 07:42 PM
All is well with the clutch grabbing through 4th, i am reluctant to drop it into 5th until it looks wide open and safe on the highway entrance ramp, i also wish not to lose my license, all i need is about 1/4 mile and i should see top end and slow back down.
I turned the boost up today on the MBC but i have not yet seen where it it's at, bad weather was moving in, earlier today i was hitting 12.5 lbs with the clutch holding, i am shooting for around 14.5 to 15 lbs. The car makes my short hairs stand up,very exciting...... |
Mike Bellis |
Aug 16 2011, 07:48 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I feel your joy! Nothing quite like the boost kicking in... (IMG:style_emoticons/default/wub.gif)
socalstuttgart |
Aug 16 2011, 09:44 PM
Member Group: Retired Members Posts: 159 Joined: 2-September 07 From: Los Angeles, ca Member No.: 8,067 Region Association: Southern California |
Have fun!!! You're having fun... have more fun! Like you need me to tell you that. Ridiculous.
moparrob |
Aug 16 2011, 09:47 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
Out of curiosity, what do you estimate your peak HP to be with 13 lbs. of boost?
Man I am JEALOUS, I admit it freely... |
iamchappy |
Aug 17 2011, 07:11 AM
Should be close to around 400hp at 14.5
iamchappy |
Aug 17 2011, 07:33 PM
I feel like a kid who just got his license, i drive around come back to the house, sit in the driveway for a few minutes in the car, back out again and drive around some more.
Driving my car is more fun than girls! |
iamchappy |
Aug 17 2011, 07:41 PM
moparrob |
Aug 18 2011, 12:22 AM
If you don't mind me asking, out of curiosity, what would you ballpark figure the cost of taking a stock 3.0 and converting it to the same turbo setup you have. This would include a total rebuild, new P&C, all fuel injection system upgrades, clutch, etc.?
Have I told you I am soooo jealous? Mine sits on jack stands awaiting its stock 3.0.... |
eric9144 |
Aug 18 2011, 08:38 AM
Advanced Member Group: Members Posts: 2,756 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
I think it's time for a new video...
Also, I think we're ALL jealous, it's not just you moparrob! (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) |
iamchappy |
Aug 18 2011, 09:24 AM
Cant be done cheaply, you can save a lot by using used parts in good condition, and fabricating yourself. Difficult for me to estimate the cost to many variables.
The advantage of using 3.0 engine as i did, I had it and it had to come apart, it makes more power and hp than a 3.3, bigger valves and ports, SC cams and crank, and because of the longer stroke rods, spins quicker and freer than a 3.3 engine. Downside is all of the things you have to add to it, and machine to make it work. IMO You would be better off looking for a good used 3.3 engine. This is what i had to do: 3.3 pistons and cylinders/rings from a 91 C2 machine to offset 3.0 rod bushing for stroke. new bearings new valves/guides high performance springs and retainers twin plug heads 930 oil pump Supertec head studs flywheel starter ring Twinplug distributor KEP stage 2 pressure plate and throwout bearing Renegade Kevlar clutch disc Bosh 044 fuel pump MSD BTM ignition 7th injector MSD RPM switch and pressure switch for 7th injector Complete Intake fuel head and injectors for an 86 Euro 930 Turbo 3.3 fuel accumulator and filter K27 Turbo scavenge pump Tial wastegate Tial BOV, although the 930's BOV would work if intake is fabricated to do so Intercooler fabrication of exhaust and intake pipes with assorted silicone pipe connectors. LSD transmission And big brakes to stop the thing...... You can use your stock 3.0 by adding the 7th injector adding the MSD BTM electronic ignition and running no more than 8 to 9 lbs of boost short duration, or 6. Then all you would need are the Wastegate, Bov, intercooler, Turbo and fabrication for it all to work, I originally started out on this endeavor using parts from and old BAE turbo kit. This can be done for under 4,000. All worked very well until the oil pump seized which had nothing to do with the engine being turbocharged. I think if you add up the $'s yourself you can see why a 930 3.3 engine or turbocharging the stock 3.0 without adding all of the stuff i did would be the way to go. At 8to1 compression running 8lbs of boost the engine will make up to 350hp. |
iamchappy |
Aug 18 2011, 09:27 AM
GOPRO HD camera not in the budget right now, i will try my hat cam trick again soon.
get off my lawn |
Aug 18 2011, 05:39 PM
Member Group: Members Posts: 168 Joined: 18-August 11 From: west coast Member No.: 13,462 Region Association: None |
Three things:
1) You can't turbo a 914 2) it looked better in black and red two tone Oh wait that's only two. |
iamchappy |
Aug 18 2011, 07:47 PM
Three things:
1) You can't turbo a 914 2) it looked better in black and red two tone Oh wait that's only two. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/shades.gif) Qarl (IMG:style_emoticons/default/idea.gif) If not who............. (IMG:style_emoticons/default/popcorn[1].gif) Miles............ |
914coop |
Aug 18 2011, 09:40 PM
Chappy
That's great, glad the clutch solved the slipping issue. Can't wait till the turbo is in our car. Still waiting for parts. Seems to be recurring theme with my 914's, ttrach destruction and the new one make us wait, Given a choice of the two I will take the waiting. Keep driving it and enjoying it, season end is approaching fast. |
iamchappy |
Aug 19 2011, 07:15 AM
Heres, one for Get Off My Lawn....
Lo-Fi Version | Time is now: 28th December 2024 - 12:53 AM |
